I am trying to send the DRONE to GPS coordinates sent from DRONEKIT
and RPI
The drone takes off and reaches the target altitude and stays there and just LANDs back without moving towards the GPS coordinates. Please advise where I am going wrong.
-- coding: utf-8 --
from future import print_function
import time
from dronekit import connect, VehicleMode, LocationGlobalRelative, LocationGlobal
import argparse
import sys
import os
import struct
import subprocess
import numpy
import dronekit_sitl
global new
global coor
latcor=float(40.7827725)
loncor=float(-73.9653627)
Set up option parsing to get connection string
parser = argparse.ArgumentParser(description=‘Commands vehicle using vehicle.simple_goto.’)
parser.add_argument(’–connect’,
help=“Vehicle connection target string. If not specified, SITL automatically started and used.”)
args = parser.parse_args()
connection_string = args.connect
sitl = None
Start SITL if no connection string specified
if not connection_string:
sitl = dronekit_sitl.start_default()
Connect to the Vehicle
print(‘Connecting to vehicle on: %s’ % connection_string)
vehicle = connect(connection_string, wait_ready=False)
def ChangeMode(vehicle, mode):
#- change auto pilot mode
while vehicle.mode != VehicleMode(mode):
vehicle.mode = VehicleMode(mode)
time.sleep(0.5)
return True
def arm_and_takeoff(aTargetAltitude):
Arms vehicle and fly to aTargetAltitude.
print("Basic pre-arm checks")
# Don't try to arm until autopilot is ready
while not vehicle.is_armable:
print(" Waiting for vehicle to initialise...")
time.sleep(1)
print("Arming motors")
# Copter should arm in GUIDED mode
vehicle.mode = VehicleMode("GUIDED")
vehicle.armed = True
# Confirm vehicle armed before attempting to take off
while not vehicle.armed:
print(" Waiting for arming...")
time.sleep(1)
print("Taking off!")
vehicle.simple_takeoff(aTargetAltitude) # Take off to target altitude
# Wait until the vehicle reaches a safe height before processing the goto
while True:
print(" Altitude: ", vehicle.location.global_relative_frame.alt)
# Break and return from function just below target altitude.
if vehicle.location.global_relative_frame.alt >= aTargetAltitude * 0.95:
print("Reached target altitude")
break
time.sleep(1)
ChangeMode(vehicle, “AUTO”)
coor=LocationGlobalRelative(latcor,loncor,45)
print(coor)
print(“Set default/target airspeed to 3”)
vehicle.airspeed = 3
vehicle.simple_goto(coor, groundspeed=10)
print(“Returning to Launch”)
vehicle.mode = VehicleMode(“RTL”)
arm_and_takeoff(45)
Close vehicle object before exiting script
print(“Close vehicle object”)
vehicle.close()
Shut down simulator if it was started.
if sitl:
Walt
