DroneCan ESC Issue
Hi everyone,
I am integrating a MAD AMP-X 200A V2 ESC with a Cube Orange using DroneCAN.
I followed the ArduPilot documentation here:
https://ardupilot.org/copter/docs/common-uavcan-escs.html
Problem summary:
The ESC never appears on the DroneCAN bus.
In Mission Planner → DroneCAN → MAVlinkCAN1 mode, I only see:
  • Node ID 10 (Cube Orange)
  • Node ID 127 (Mission Planner virtual node)
The ESC node never shows up. There is no heartbeat or NodeStatus message from the ESC.
What has been verified so far:
  • CAN wiring is correct (CAN_H, CAN_L, GND verified).
  • 120 ohm termination is installed.
  • CAN parameters in ArduPilot are set as:
    CAN_P1_DRIVER = 1
    CAN_D1_PROTOCOL = 1
    MOT_PWM_TYPE = 9
  • The ESC powers on normally and beeps continuesly.
Before proceeding with firmware flashing or obtaining the MAD ESC programming tool, I would like clarification from anyone who has experience with this exact model.
I have used other CAN esc’s (AM32 Drone CAN ESCs, for testing) on the cube orange with this setup and they worked great**.**
Below you can see pram list I am using
param list.param (21.0 KB)
Hello There,
As I found out I should assign some value to CAN_D1_UC_NODE, which will help Cube to find and read ESC, But I don’t know what should I type. does anyone have any idea what should it be?
P.s.
Here’s the manual which was given to me by Mad Motors
MANUAL
We found out that ordered esc’s are cyphalCAN and not DroneCAN protocol.
I couldn’t find any guide to connect cyphalCAN to ardupilot, is there any way to do so?
No. Want to read all about why? Cyphal Support
