Hi all,
I recently changed the motors on my 450 mm quadcopter and when trying to fly it for the first time, I encountered terrible shaking and vibrations when the throttle was increased to around 50%. Here are two videos of the shakes: this and this. If you look at the orange vibration dampener plate under the Pixhawk, you can see the vibrations fairly clearly. For reference, I am using EMAX Pro 2810 1150kV motors with a 5200 mAh 3s Lipo battery and 35A Flycolor Raptor 5 ESCs. The flight controller is a Pixhawk 6C. Previously, I was using 2212 920 kV motors and the drone flew, but the motors were being overworked due to my drone’s weight and so I decided to upgrade the motor.
I did not try and takeoff as the drone felt very unstable and I did not want to damage any parts. Is there a fix for this? My initial thoughts are the motors I bought are broken, or that the ESCs are being overworked when the throttle is increased and this is causing some issues. Could it be from bad weight distribution? A bad frame? Bad PID tuning? If there is any information about this issue or ways to fix it in the Arducopter parameters please let me know.
Here is a link to the bin file of the flight test: this.
Any help is appreciated!
Thanks in advance!
