With the dronekit library and opencv via Gazebo Simulation, I want it to follow when I show something red on my webcam.Now it does, but whenever it sees red, the video keeps freezing and I can’t follow.
Where am I going wrong or what should I do?
I would be glad if you help
import cv2
import numpy as np
import threading
import logging
import dronekit_sitl
from dronekit import connect, VehicleMode, LocationGlobalRelative, Command, LocationGlobal
import cv2
import argparse
import time
from pymavlink import mavutil
# Connect to the Quadcopter
parser = argparse.ArgumentParser()
parser.add_argument('--connect', default='127.0.0.1:14550')
args = parser.parse_args()
vehicle = connect(args.connect, baud=921600, wait_ready=True)
vehicle.airspeed = 3
vehicle.groundspeed = 3
ay = 0
ax = 0
class Velocity():
def set_velocity_body(self, vehicle, vx, vy, vz):
msg = vehicle.message_factory.set_position_target_local_ned_encode(
0,
0, 0,
mavutil.mavlink.MAV_FRAME_BODY_NED,
0b0000111111000111, # -- BITMASK -> Consider only the velocities
0, 0, 0, # -- POSITION
vx, vy, vz, # -- VELOCITY
0, 0, 0, # -- ACCELERATIONS
0, 0)
vehicle.send_mavlink(msg)
vehicle.flush()
time.sleep(0.5)
def arm_and_takeoff(aTargetAltitude):
while not vehicle.is_armable:
time.sleep(1)
vehicle.mode = VehicleMode("GUIDED")
vehicle.armed = True
while not vehicle.armed:
time.sleep(1)
vehicle.simple_takeoff(aTargetAltitude)
while True:
print(" Altitude: ", vehicle.location.global_relative_frame.alt)
if vehicle.location.global_relative_frame.alt >= aTargetAltitude * 0.95:
break
time.sleep(1)
def go(p):
vehicle.simple_goto(p, 3)
def center_shape(x, y, w, h, frame, t, color, a):
cv2.putText(frame, color + str(t), (int(x), int(y + 20)), cv2.FONT_HERSHEY_SIMPLEX, 0.75, (0, 255, 255))
M = cv2.moments(a)
ax = int(M["m10"] / M["m00"])
ay = int(M["m01"] / M["m00"])
cv2.circle(frame, (ax, ay), 3, (255, 255, 255), -1)
cv2.putText(frame, "center", (ax - 20, ay - 20), cv2.FONT_HERSHEY_SIMPLEX, 0.5, (255, 255, 255), 1)
return ax, ay
def moving(ax, ay):
v2 = Velocity()
if ax < 240:
v2.set_velocity_body(vehicle, 1, 0, 0)
print("Forward")
elif ax > 240:
v2.set_velocity_body(vehicle, -1, 0, 0)
print("back")
if ay > 240:
v2.set_velocity_body(vehicle, 0, -1, 0)
print("Left")
elif ay < 240:
v2.set_velocity_body(vehicle, 0, 1, 0)
print("Right")
def opencv(ax, ay):
capture = cv2.VideoCapture(0)
center = False
lower_red = np.array([130, 150, 150])
upper_red = np.array([200, 255, 255])
time.sleep(0.1)
while True:
t = 0
ret, shot = capture.read()
cv2.circle(shot, (240, 240), 3, (255, 255, 255), -1)
blur = cv2.GaussianBlur(shot, (11, 11), 0)
hsv = cv2.cvtColor(blur, cv2.COLOR_BGR2HSV)
j = 0
mask = cv2.inRange(hsv, lower_red, upper_red)
kernelOPen = np.ones((20, 20))
mask = cv2.dilate(mask, kernelOPen, iterations=5)
countours, _ = cv2.findContours(mask, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_SIMPLE)
if j == 0:
for a in countours:
area = cv2.contourArea(a)
peri = 0.01 * cv2.arcLength(a, True)
approx = cv2.approxPolyDP(a, peri, True)
if 10 < len(approx) <= 20:
if area > 1000:
x, y, w, h = cv2.boundingRect(a)
color = "Fire"
ax, ay = center_shape(x, y, w, h, shot, t, color, a)
moving(ax, ay)
cv2.imshow('cam', shot)
cv2.waitKey(1)
if (180 <= ax <= 300 and 180 <= ay <= 300):
center = True
if center == True:
lat = vehicle.location.global_relative_frame.lat
lon = vehicle.location.global_relative_frame.lon # current location
currentLoc = LocationGlobalRelative(lat, lon, 2.5)
vehicle.simple_goto(currentLoc)
time.sleep(7)
capture.release()
cv2.destroyAllWindows()
break
arm_and_takeoff(5)
time.sleep(2)
p = LocationGlobalRelative(-35.36309829, 149.16520472, 5)
go(p)
time.sleep(5)
opencv(ax, ay)
vehicle.close()
