i did that but i am having issues with the esc heating
the quad rebooting midair and falling down
I should have been more clear. That’s how to calibrate the current monitor.
Did what? Does your craft hover ~4A as the log shows? Just put some regular 2 blade 4" props on there. What is the take-off weight with the battery?
I don’t see much reason for the ESC’s to overheat. Drop the rate D-terms to .001 and reset these for the 4" props:
PSC_ACCZ_I,0.46
PSC_ACCZ_P,0.32
still the same issues, esc heating
i am replacing the esc and will update you on the same
also a quick qustion, i use silicon to cover esc components, could that be an issue?
Probably.
