The title says it all. I cannot seem to find a Dragonlink telemetry module anywhere. Does anyone know where I can buy one which is in stock / an alternative with a similar range + capabilities?
If the alternative telemetry cannot handle remote control commands (pitch/yaw/roll/thr for manual flying), Ill use ELRS because I already have a receiver and transmitter capable of decent range from previous planes
I have both Dragonlink and RFD (and Crossfire) and would no longer recommend either system.
Dragonlink primarily because there have been no updates for 3 years and the availability is very modest.
The RFD is rather old hardware and very complicated to configure. Compared to Crossfire on the same frequency, it’s almost like a museum.
Crossfire has suffered from organizational changes over the last few years, and availability has become worse in some cases.
You can continue to use all of these systems, but if you are buying a new one, I would definitely recommend ExpressLRS. The availability is very good, the selection is large and the performance of the system is very good.
As a direct replacement for a Dragonlink system, I would (and have) used a Radiomaster Bandit and am very satisfied.
IMHO there is currently no way around the ELRS system, at least not if you fly with a flight controller, which is to be expected here.
ELRS doesn’t do telemetry unless it is via ELRS airport. I wish it did do telemetry. Maybe I will try Airport for once: ELRS compared to the alternatives is fairly cheap 4 me.
I guess you put a Radiomaster Bandit on your RC; what do you use on the plane side? I guess if you are using ELRS airport you are using a second Bandit for mission control-side telemetry.
EDIT: I am stupid. Just found the ELRS Bandit receiver
With ExpressLRS Mavlink works via branch “mavlink-rc”. I don’t use Airport, which is not good for Mavlink.
Exactly, there are also Bandit receivers.
The Bandit can also be used in relay mode in combination with 2G4 ELRS. Although this is still being tested and not yet a release, it is very promising.
Anyone who is involved with Dragonlink, RFD and/or Crossfire should order a Bandit system to test and compare for themselves …
Makes sense from my point of view. I flew with the branch mavlink-rc today. I had no problems. It is currently a dev / test version, so not yet a release. You should keep an eye on it and use it with a certain amount of caution.
