Hello, I am a beginner at using Ardupilot and SITL. It has been days since I have been trying to graph the vehicle state of the default quadcopter when running sim_vehicle.py. The problem is I could not find the command to graph different vehicle states, such as altitude. Typing “graph” and double tab should have given the completion list for graphing, but it is not working for me. The double tab function works before I run sim_vehicle.py; however, after I run it and try to use the function to find lists of commands to graph vehicle state, it does not work.
I have followed the instructions on the following Ardupilot discussion but it still have not solved the problem
I do not know where else to find a resource to fix this problem so I need help in either solving the problem by fixing the double tab function or if anyone can share where I can find a list of all MAVproxy commands for all the modules.
