did you change the pixhawk serial parameters and the mission planner settings?
that is normaly the cause of non loading parameters.
inverted fc: what exactly is inverted ? the wirering? or the artificial horrizon?
DL쪽 RX, Tx 세팅에는 이상 없습니다. FC쪽 세팅값을 캡쳐를 잡아 올리시던가 아님 Param파일을 올리세요. DL여러대 세팅해 봤는데 블루투스 모듈 자체 말고는 문제 생긴적 없었습니다. 동네가 어디신지 모르겠지만 가까운 동호회 나가시면 금방 해결해 줄겁니다.
@Ricoman did you get this working? I use DL telemetry all the time. However, before I spam the thread with diagrams and screenshots, I just wanted to know if it was needed. Thanks.
@davidbitton this is not spam to publish a working and tested set-up. The thread subject is DL telemetry. Please go !
Sorry … I have not solved it yet …
During the weekend, I was completely off on this issue doing other things.
Hi.
Your words give me great courage.
You said that there is no problem with the TX and RX settings on the DL.
I changed the settings for this one and the other.
I will go through the factory reset and try again.
If it’s a parameter problem with PixHawk, I’ll test it first and send you my parameters.
I am very busy on the weekends, and I have completely taken my hand off this problem.
Now it’s restarting.
This is what it means to be upside down.
did you set up the adhs orientation?
cube had a inverted setup some time ago.
No. I did not set it.
If you connect to an existing telemetry, it will come out properly.
Even if I lean fc in that state, the screen is fixed upside down and does not move.
there is no connection.
did you follow everythign step by step? non flowcontrol
Hi
It’s been a very long time.
I tried setting the non flow control, but it did not help … I do not know what the problem is now …
Wow … I really can not believe it.
I finally did this.
Telemetry has worked,
Unfortunately no rc status now
DL of TX is solid state of red light …
It will be perfect if i fix this!
