This image is incorrect:
It is embedded on this page:
https://ardupilot.org/copter/docs/common-3dr-power-module.html
The first 2 pins are power and the last 2 are ground. The diagram shows the second pin to be ground when it is power.
Thanks.
Thanks.
Because it shows as a black wire? What difference does that make? Many of the cable sets for those Power modules have one red lead and the rest black. Like the one shown on that same page.You always wire for the function.
Ground is unlabelled in the image however 2 of the 3 black wires are ground and the third is not so the image is confusing and could cause someone to have a short circuit.
