This is a re-post of Dodeca Hexa with “Flier OPTO ESC” – AUX Output Channels are not working correctly
It seems like that the interest on a Dodeca Hexa Frame with a specific Flier ESC is very low.
But I am still sitting with the problem. This is why I try it with this new post.
In this post I will concentrate only on the main problem: “only 10 of 12 Motors get a Signal”
(the wrong motor number allocations I can change in the settings. Not the right way, but it works)
I organized an oscilloscope to be able get some facts:
On 10 of 12 outputs of my flight controller (Cube 2.1) I am getting a perfect signal:
These motors are also working as expected if I perform a motor test
On 2 outputs I get no signal at all:
I tried all scenarios: motor test, armed and live…
(with connecting a servo tester instead of the FC connections: it works!)
It could be a software problem (which I believe) or a hardware problem. But I really have no idea how to find it out and how to go ahead. I need assistance in any case: Hardware or software…
Important note: These signals (the good ones and the bad ones) I am getting in all test environments: Disarmed, armed and motor test. It really can’t be a wiring problem, because if I am using a servo tester, the 2 problem motors/ESC’s are working perfectly.
I hope to get with this post some more attention and hopefully somebody have an idea what could be wrong. I strongly believe in a firmware problem. How can I bring this to the attention to a developer?
Thanks in advance
Peter
