Documentation Update Required [Resolved]
Where can I request a “bug fix” in the documentation?
It’s mentioned here that the vehicle can only be rudder armed when in manual modes. However we’ve tested many times and one can arm the aircraft in auto mode, causing a very dangerous scenario.
https://ardupilot.org/plane/docs/parameters.html#arming-rudder-arming-with-rudder-enable-disable
go to the bottom of that page and click the github issue tracker then type what you think needs changed.
