Document about Measuring Vibration does not match the source code
While researching methods for calculating vibration, I came across the following link: Measuring Vibration — Copter documentation (ardupilot.org). The document describes the process as “High-pass filtering the raw values at 5 Hz to remove the vehicle’s movement.” However, upon reviewing the associated code referenced here: ardupilot/libraries/AP_InertialSensor/AP_InertialSensor.cpp at master · ArduPilot/ardupilot (github.com), I found discrepancies between the description and the code implementation.
In the code, the filters utilized in the vibration calculation are as follows:
  • LowPassFilterVector3f _accel_vibe_floor_filter[INS_VIBRATION_CHECK_INSTANCES]
  • LowPassFilterVector3f _accel_vibe_filter[INS_VIBRATION_CHECK_INSTANCES]
Both of these filters are low-pass filters. This leads me to question whether “accel_vibe_floor” actually includes the vehicle’s movement.
Thank you for your assistance.
hi,
I am also seeing both to be lowpassfiltervector3f. Did you find any info how it works?
Regards,
James.
Probably it uses low pass and then subtracts the result from the signal, effectively creating a high pass.
Thanks Amil, that makes sense.
Regards,
James
Oh dear,
I did not realize that. Indeed the subtraction acts as a high-pass.
Thank you!
