hi im working on pixhawk 2.4.8, with copter 3.6 dev, so if i click in the servo panel the servo nº9 high (1900 PWM) the servo responds ok, but if i put a do set servo comand in a mission the servo do not work , anybody know possibly wy?
thank you very much
Could you provide the .bin log showing the issue? Perhaps it’s not being executed because the navigation command just before it is completing too quickly but a log should clear up if this hunch is correct.
thanks, i cant provide the log now, but for some reason i chanque to the servo nº 10 and itworks
