Do LUA scripts work on real controllers, or is it just for simulation
Absolutely. There are Lua scripts being used for many, many different purposes. There is a minimum hardware requirement.
that is, if I load the lua script onto my controller and not into the simulation, will it run?
Sorry for the stupid questions, I just asked ChatGPT, and he said lua scripts for simulation
Well yea if everything is done correctly:
Lua Scripting
Don’t even mention a ChatBot here on the forum. It’s the quickest way to get your post deleted. Posting the response that is, you are fine so far
And could you jump in, I have a mate a 405 hdtv controller, but it only has 1 MB of flash memory, and this does not allow me to use lua scripts, do you know any way to run scripts on my controller
Thanks a lot for the answer
No, you are out of luck with scripts with that FC. I recently replaced a couple F4’s for this reason.
And what compact FC do you use with support LUA
If by compact you mean the 30x30 or 20x20 board formats I have several Matek H743’s (Slims and a Mini). I replaced the F4’s with Cube Orange +'s.
Thank you very much
