Hi, i tried using servo but the thought is the same with my current set up. This wont trigger do_digicam_control during mission flight. Actually, i already have a working photo and video switch, its just tha i wanted it to take photo on each waypoint everytime i call the command do_digicam_control, on that instance only. But do_digicam_control wont trigger on my mission.
I would like to clarify Sir, will this only trigger i put the PWM into 1000? Example the PWM 1000 will trigger photo. Or will it trigger still even though i my switch is on 2000 PWM because i will be recording video.
But on mission, my switch PWM will be 2000 because i will be using video. If i did set this, without turning on to PWM 1000, will this still be trigger? As long as its the value for my photo trigger? Thanks much.
