Hello all,
I am trying to get a quad plane to hover indoors without GPS. It flies outdoors with GPS just fine. It will not pass prearm checks unless I disable accel and gyro checks (which I do not want to do.) I Changed the following parameters:
Arming_Check,4086 or 7670 (the difference is if GPS Setup is checked but result in the same behavior)
GPS_Type,0
Ek3_GPS_Check,0
AHRS_USE_GPS,0
EK3_GPS_TYPE,3
When I try to arm I get an error of “PreArm:” that’s it, no description following the error.
If I change Arming_Check to 3558 or 7654 to disable INS check it passes the arm check.
What am I missing here?
Thanks
Travis
2Feb18_XLVert.param (16.2 KB)
