Hi, this is a rangefinder I had previously
This is the arduino code I used: I worked. But In don’t know how to use it with pixhawk. Plz help
#define MAX_RANG (520)//the max measurement vaule of the module is 520cm(a little bit longer than effective max range)
#define ADC_SOLUTION (1023.0)//ADC accuracy of Arduino UNO is 10bit
int sensityPin = A0; // select the input pin
void setup() {
// Serial init
Serial.begin(9600);
float dist_t, sensity_t;
void loop() {
// read the value from the sensor:
sensity_t = analogRead(sensityPin);
// turn the ledPin on
dist_t = sensity_t * MAX_RANG / ADC_SOLUTION;//
Serial.print(dist_t,0);
Serial.println("cm");
delay(500);
FAQ
I looked up Maxbotix Analog Sonar — Plane documentation and found out that i’ll need to set 4 parameters:
[RNGFND1_PIN]= “14” for Pixhawk’s ADC 3.3v pin #2 ----> This is fine
[RNGFND1_MAX_CM] = “520” (i.e. 7m max range) if using EZ0 or EZ4, “1000” if using EZL0 ----> This also I measured
[RNGFND1_SCALING] = “2.04” (i.e. 7m / 5v) if using EZ0 or EZ4, “4.08” (i.e. 10m / 5v) if using EZL0 ----> What about this? 7m/5 = 1.4 not 2.04 right? I thought of 5.2m/5
[RNGFND1_TYPE] = "1” (Analog) ------> This is fine
I think I got it, it should be 0.01(Vout)*520(max.range)/3.3(Vin) == 1.58
