I guess someone must have to approve posting to the development list as “New Topic” is greyed out there. But it seems I can post here.
I’m completely new to ArduPilot software development, but not to software development. I just forked the source from Github and built it from source. I was impressed how easy this was.
Now I have a question: How are the various hardware target beads defined? I mean when I type “./waf list_boards” where does that list come from?
Next question: how do I know which physical flight controller board matches up to which was target. It should be clear but I don’t want to guess.
Some place there must be a big table that defines the characteristic of each target. I’d like to learn to add new targets.
To expand a little, whilst the legacy/nuttx builds/targets are included in the waf make files, for ChibiOS the list is generated from the hwdef directory.
This means if you add a new target, you can simply ./waf configure board=new_target (where new_target is a folder in hwdef) without having to explicitly add new_target to the build system.
If your new board uses an MCU that is already supported (F412, F405, F427, F745, F767, maybe a couple of others), adding a new hwdef.dat is all that is necessary. If you need to add a new MCU it’s a bit more involved but a bunch of that is automated too.
Thanks. That is most of what I need to know. The file is called “hwdef.dat” and “Gitter”.
I have an idea I want to explore. A python program called maybe “beta2ardu” Give it a working Betaflight configuration for a board and it makes the files needed to support that board on ArduPilot.
The Betaflight CLI dump has everything I can think of you’d need to describe the board, specifically what resources are connected to which ARM M pins, the type of IMU and so on.
I will try ti implement one by hand and see how it goes.
