Attendee count (max): 24
Pre-Agenda:
- Discussions on discourse consistency
UTC1105 - Compass ordering
- Sidâs done some significant work which we have to discuss laterâŚ.
UTC1107 - Welcome to Henry and Matt to the devteam
- Vote was held over the last week
UTC1108 - https://github.com/ArduPilot/ardupilot/pull/12886
- Bad fix for whatever problem
- But master is currently broken
[10:10 AM] (Channel) JW: i just tuned in and looked yes
[10:10 AM] (Channel) JW: iâve been OOO the past two weeks
- [10:12 AM] (Channel) JW: tomorrow
- Jacob and co will look at this so we donât need to merge it
UTC1113 - https://github.com/ArduPilot/ardupilot/pull/12882
- MERGED!
- Simulated safety switch
UTC1114 - https://github.com/ArduPilot/ardupilot/pull/12881
UTC1115 - https://github.com/ArduPilot/ardupilot/pull/12880
- Merged!
- Another enum-class change, this time in servo library
UTC1116 - https://github.com/ArduPilot/ardupilot/pull/12879
- Move the pragma thing into the .cpp
- Should be flight-tested
- Tridge would like to review before merge
- We should testing DCM fallback in autotest
- Behavioural?
- Lower gate value parameters
- Really long GPS delay
- Fusing GPS flag
- MdB: We have talked about how EKF_STATUS_REPORT needs an extension to say what lane it is actually using, and similiarly saying âLANE_DCMâ would be valid I thinkâŚ
UTC1123 - https://github.com/ArduPilot/ardupilot/pull/12877
- When we have a critical failure MissionPlanner doesnât say anything
- Tridge opened a mission planner issue for the SYS_STATUS bits
- This will have MissionPlanner show something
- Thus we are getting bug reports back from core dev team members only
- [10:35 AM] To Weekly devcall: We should be making internal errors as scary as possible IMO.
- [10:35 AM] (Channel) db: status text âyour copter is behaving so badly we, the developers would like to see the logâ
- [10:36 AM] To Weekly devcall: @db that sounds good, actually.
- Use name of enumeration and put in a 30s interval message with its name
- MissionPlannerâs statustext limit is a significant problem
- Peter to redo as a more elaborate patch using the maximum of the vehicleâs status and the base class status
- Randy can help testing in Mission Planner
UTC1136 - https://github.com/ArduPilot/ardupilot/pull/12869
- Behaviour change for existing frame types 0 and 1
- Wonât impact any users, probably
- Need to ensure continuous function across angle changes
- Rate change so shouldnât be too bad
- Donât want an oscillation
- Needs a comment on using roll for pitch and vice-versa
- Makes things consistent with Copter documentation
- Leaves behind a couple of special cases, âthough
- The two classes are still useful
- No yaw torque + class would be what youâd choose to fly a plus frame tailsitter with
- This will give you two options for the same phrase
- Parameter conversion?
- Tridge: change in behaviour is probably OK in this case so long as we put it in the release notes
- Pierre L was impacted by the change when he tried out this PR and needed to change a parameter
- Versioning of Wiki parametrers is coming along
- Henry will put a section in the wiki for âPlane > 4.0â for this feature behaviour change
- Mark will eliminate the discontinuity in rate limit
- Mark to eliminate logging code to be killed or cleaned up significantly
- Debug code was originally in for dynamic gain scaling
- Rather unreliable as it turns out
- Pierre Lâs logs showed that it wasnât really required anyway
UTC0002 - https://github.com/ArduPilot/ardupilot/pull/12864
- https://github.com/ArduPilot/ardupilot/issues/12838
- Compass cleanup and bugfixes
- Vehicles having heading problems
- EKF being annoyed rather than fly-aways
- Calibration not getting diagonals/off-diagonals filled in
- Red-herring
- Probably working OK as the sphere fit is better than the ellipsoid
- Merged
- Hanging brace thing
- Tridge likes having a consistent style
- https://github.com/ArduPilot/ardupilot/pull/12864/files#diff-3e07895a0da57267a05c962290715e46L352
- For library maintainers weâve traditionally allowed latitude
- Scripting and gps and ekf all have slightly different styles
- [11:06 AM] (Channel) db: my personal opinion is âdont careâ, or alternatively, âif editing an existing file, use the same layout as the file/s you are inâ
- [11:06 AM] (Channel) MdB: buzz thats what Iâve stuck with
- [11:06 AM] (Channel) MdB: And Iâm actually okay with that
- [11:07 AM] To Weekly devcall: @davidbuzz thus bringing this up. Several style changes were made (for the good), but the hanging-brace thing is contentious.
- [11:07 AM] (Channel) HW: astyle --options=Tools/CodeStyle/astylerc
- [11:07 AM] (Channel) MdB: But I periodically get larger change sets of âcovert style in scriptingâ for example which Iâve historically just closed as noise
- Randy likes bracket on next line
- In general bracket on next line
- If maintainers want to use a different style, thatâs OK
- Tridge doesnât want a commit hook enforcing style changes
- Merged!
- Real underlying issue:
- World magnetic model tables
- EKF got greater resilience to lots of things
- Made us dependant on actually getting milligauss from the sensor
- Turns out one very popular sensor is off by 16.7%
- Vendor is actively working on the problem
- Backwards compatibility is a real problem as the calibrated offsets are all wrong
- Make compass calibration process look at GPS lock
- Rescale the compass calibration output
- COMPASS_FLAGS parameter
- Bits indicating scaling-checked (had GPS lock)
- EKF wouldnât do earth field unless compass library indicated offsets were corrected during calibration
- If people upgraded to new firmware the WMM stuff would be disabled
- Would be re-enabled if another cal was done
- Prearms canât really be used to catch the bad scaling because on-ground errors are > 17%
- 17% is within Earth magnetic fieldâs variation
- In-flight check would be way too much yelling
- WMM significantly improved our compass handling
- Yaw alignment was done with a single sample from compass
- Used that as field intensity
- If it was a good sample - great
- Motor running hard? Bad earth field!
https://github.com/ArduPilot/ardupilot/pull/11456
- Introduced a massive offset
- Before == fly-away
- After == happy flight
- In-flight testing was done using different code on different cores
- Log is actually same flight
- This was very good for bad vehicles
- Bad for good vehicles
- As they are now dependant on compass scaling being correct
- The can set the EKF_LIM to zero to use the old single-sample code
- Should we whitelist compasses with correct scaling
- Problematic given emulated compasses
- Should we disallow compass cal without GPS lock
- [11:28 AM] (Channel) MdB: I canât let users end up with different results depending on lock, I need to be able to constrain the path. Could be a param to require it though
- Only uses tables if you have GPS lock while flying
- [11:28 AM] (Channel) MdB: We can even report MAG_CAL_FAILED_NO_POSITION if we add it as a check for the calibration
- If radius comes out too far from WMM then you can complain to the user
- Additional fitness on the radius
- [11:29 AM] (Channel) MdB: Randy: Iâd take the hard requirement of GPS if it makes it better
- [11:29 AM] (Channel) MdB: I need to know users are going down the one path
- [11:29 AM] (Channel) MdB: So if we are going to change behaviour based on how calibration went then I want to be able to force how they did the cal
- Sid: get input from user about location
- Check all compasses have some radius?
- We should log the radius during the calibration
- Just use direction of vector rather than length?
- Tilt-corrected yaw sensor compass algorithm
- Normally uses as 3D sensor
- Concept:
- Use intensity from single sample, inclination/declination from tables
- Try to get EKF to not care about intensity?
- Polar coordinates rather than xyz in EKF
- Rather large change
- Realistic?
- Not really, complete reformulation
- Change constraints and have max-radius error
- Log analysis first step:
- Compare compasses against earth-magnetic-model expectations
- Should include radius in both compass calibration messages
- Correct intensity as part of calibrationâŚ
- Ensure radius is correct for that part of the planet
- Calibrating inside == bad
- [11:41 AM] (Channel) RL: I do that all the time
- [11:41 AM] (Channel) DB: I do compass-cal indoors and without a gps all the time.
- [11:41 AM] (Channel) DB: ⌠and I usually do it with a usb cable.
- [11:42 AM] (Channel) MdB: dont do compass cal indoors, thats a genuine problem
- [11:42 AM] (Channel) OB: lol me too! (sometimes)
- [11:42 AM] To PB: Why argue when we can measure?
- [11:43 AM] (Channel) MdB: yes it is. It can blow up very very badly. Depends what is around in your house
- [11:43 AM] To PB: I have ths huge steel ibeam running underneath my office. Do you?
- Randyâs never had issues calibrating indoors
- [11:44 AM] (Channel) OB: One wooden roof, no pb
- [11:45 AM] (Channel) OB: (no second floor)
- [11:45 AM] (Channel) MdB: cars near by outdoors
- [11:45 AM] (Channel) MdB: The best one Iâve seen was someone with a nametag held on with a magnet
they rolled the vehicle by it and the calibration was uh intresting
[11:25 AM] (Channel) Gus7119: Tridge sorry almost out of battery so will be gone soon. The Marketing and individual diagrams are all with graphic artist
UTC0040 - https://github.com/ArduPilot/ardupilot/pull/12863
- Point in a direction, say calibrate, done
- Awesome for really large vehicles
- No diagonals or off-diagonals
- Sid is worried about corner-cases, particularly on small drones and moving in 3D
- Motor interference would swamp this effect
- Diagonals are maybe 5%
- 5% of 250 milligauss is ~12
- EKF doesnât care about this
- If the diagonal is 1.2
- Then youâre at .6 or .7 innovations
- And the EKF might start rejecting
- Vast majority of our user base wonât care about diagonals
- Concept
- Do the simple cal
- Then rotate vehicle watching bars in MissionPlanner
- Above .2 would be bad
- Will go badly wrong if you point vehicle in different direction to the direction you tell it it is pointing in
- Randy will test this
UTC0055 - https://github.com/ArduPilot/ardupilot/pull/12859
- Toshibacan log and consume motor temperature
- Merged
UTC0056 - https://github.com/ArduPilot/ardupilot/pull/12855
- Generate random vehicle size
- Point objects velocity to zero
- Wonât ever fly out of range
- So theyâll accumulate
- merged
UTC0057 - https://github.com/ArduPilot/ardupilot/pull/12799
- Clean up init failure handling in ekf2
- Randy deliberately failed the allocation and it worked appropriately
- merged!
UTC0058 - https://github.com/ArduPilot/ardupilot/pull/12756
- Plane tiltrotors allow vectored motor tilt when disarmed
- More contentious is the 2s arming delay patch
- Force internal ramp time instead?
- Mark will remove the arming delay stuff
- Mark will add a Q_OPTION to control this behaviour
UTC0105 - https://github.com/ArduPilot/ardupilot/pull/12643
UTC0107 - https://github.com/ArduPilot/ardupilot/pull/12576
- Sanity check was added for send-to-components
- Merged
UTC0110 - https://github.com/ArduPilot/ardupilot/pull/12158
- LTM support
- Should we make all semaphores recursive?
- How many non-recursive semaphores?
- Thereâs a flag to make semaphores recursive in ChibiOS now
- merged!
UTC0114 - welcome to Henry (again) to devteam
- Now heâs undeafened on the call
UTC0114 - tridge chasing i2c issue
- Watchdog reset
- Cross-couple GPS send line with i2c SDA line
UTC0115 - RC4 for Rover is out there
- Not a lot of feedback
- Would like some more
UTC0115 - closed
