CraigElder
(Craig Elder)
1
Issues & Pull Requests
ChibiOS
Plane
Copter
Rover
CraigElder
(Craig Elder)
2
Attendee count (max): 24
UTC2305 - https://github.com/ArduPilot/ardupilot/pull/9631
Is this a good change?
Wrapper?
Makes code larger!
Having to go look at the wrapper sucks
On heliplane the indirection is actually useful
[10:07 AM] (Channel) MdB: If you are going to have to overload it fine, but I think the PR is alot more readable…
Randy thinks indirection for one line is not useful
The wrapper functions would make things slower but more compact
UTC2309 - https://github.com/ArduPilot/ardupilot/pull/8409
MdB has commented on the issue now
Tridge will go back through MdB’s comments now!
Randy’s keen for this one!
Parameters are one concern
[10:13 AM] (Channel) Naterater: Didn’t Tom say there is a unit that can do 100Hz GPS? Not worth supporting?
[10:14 AM] (Channel) MdB: Nate: Not that we support at this time, and we don’t poll that fast anyways
UTC2310 - https://github.com/ArduPilot/ardupilot/pull/9358
UTC2318 - ChibiOS
Removing the NuttX builds
Progress update
Aiming to get rid of the NuttX build
Issue numbers are dropping!
Solved a nunber of issues
DSMX spectrum issue
Safety mask issue
Solo gimbal twitch puzzling and hard to track down
Will probably remove NuttX anyway on this one
Need to MitM the Solo gimbal cable to nut this one out
Does Philip have the relevant parts or the part numbers
Tridge tried some buffer-size changes etc etc and it didn’t help
Still a puzzle!
OreoLED drivers still not working
Tridge and Peter might get together this week with all the parts to nut this out
I2c fix
NuttX support to be removed next week?
Waf on eclipse is working now!
Don’t need the px4 toolchain stuff any more
Use stuff straight from ARM consortium and eclipse project
Can now target all boards
Can we build the 3.5 tree with this new setup?
Should we remove NuttX entirely from the tree or just make the compiles fail?
“px4-v3 has been removed, see <webpage> for details”?
Should we provide a get-out clause?
How hard of a switch do we want to make?
Maybe had a #error for a week or two?
How about Leonard and Paul and the like - are they ready for waf etc etc?
Leonard is, tridge helped him
Paul is, tridge helped him…
Randy might be the last hold-out?
Call For Testers - Final ChibiOS testing before NuttX is removed
Tridge wants half a page of warnings explaining what’s going on if someone tries a make / NuttX build
- So a #error may not be sufficient
Randy wants to give more warning that things are going to die
Tridge was going to PR in a week
And discussion then
First PR would remove build options and submodules
Not remove the #ifdef px4 through vehicle code
Second stage to remove the _PX4 drivers etc etc and the #ifdef’d code
Need to do the submodule remove very, very carefully
[10:43 AM] (Channel) LV: Just get a Banner on ALL ArduPilot sites and FB announcing the break from make and PX4 and linking to a wiki article
Randy will create a PR to #error
More advertising required!
- Need a blog post and post that to facebook
LV thinks a banner on every page
- Randy will patch the dev wiki
Should we remove the px4-v3 etc etc builds from the Wiki?
While we’re at it - we should kill the APM stuff from the Wiki
Will discuss again in a week’s time
Craig thinks more visibility would be good
UTC2338 - documenting the supported boards
Tridge has started an effort to create example documents
Idea is to have base technical documentation stored in our git tree rather than in the Wiki
Possibly create wiki pages automatically
Supply low-level hardware stuff
- E.g. which pins are which
[10:55 AM] To Weekly devcall: Replacing information on e.g. this page: http://ardupilot.org/copter/docs/common-pixhawk-serial-names.html
Having the markdown editor in Wiki should allow users to contribute more easily
Randy would like a video on the page
Might be a several steps forward and a few back for e.g. PixHawk
Trying to explain pwm output on PixHawk 1 is complicated and needs a separate wiki page for pwm groups etc
[10:59 AM] To Weekly devcall: @tridge are you thinking entries for schematics and hw source?
[11:01 AM] (Channel) RM: for example, on the kakute-f7, it’s not super obvious to me how to plug in the receiver…
Tridge found some problems on some boards when creating these files
[11:01 AM] (Channel) Naterater: If pinouts are given, we also need a connector page labeling what side is "zero" to avoid polarity reversals.
Wouldn’t do it for something like fmuv3
It’s not hardware!
Pixhawk1 and cube black but not fmuv3!
Would have it for PixRacer but not fmuv4
Board folders
[11:07 AM] (Channel) Naterater: YES. This will avoid the confusion as well. Only Dev’s know what FMUV3 meant.
UTC0007 - Plane update
No new releases this week
Probably in next week or two
Will get differential spoiler stuff in in the next 3.9 point release
UTC0008 - Randy and Copter
UTC0011 - Randy and Rover
Rc2 will come out in next few weeks
https://www.youtube.com/watch?v=RRjOyaj2hNk
Next thing to focus on is the timing between companion computer and flight controller
Most bits are there
AP_RTC
Need to align the clocks!
ROS stuff needs to know when our IMU data was generated
ROS should be aligning clocks on the same way we do for input
[11:15 AM] To Weekly devcall: We don’t drift the clocks IIRC. tridge’s stuff doesn’t need it.
[11:16 AM] To Weekly devcall: "determining age"
[11:16 AM] To Weekly devcall: Rather than "aligning clocks"
We assume they are timestamping correctly
We assume uart timing jitter
We assume some sort of processing lag
We need the “glass time”, not message sending time!
ROS is spitting out error because we’re not responding quickly enough on timesync messages
UTC0020 - back to NuttX builds
UTC0029 - OlliW’s stuff is now being made by Jani
Will send some to tridge
Firmware is closed-source
No reason given
Bare-metal?
Schematics are available
Compiled binaries
New BetaCopter release
- Jani would like to see patches come back
Tridge would be happier with firmware available
Stm32f103
Still great to have without the firmware source
UTC0038 - https://github.com/ArduPilot/ardupilot/pull/8397
- Tridge will rebase and have another look
UTC0040 - KDE CAN
- FF will look again on Thursday
