Servers by jDrones
Dev Call Nov 19, 2018 2300 UTC
(Craig Elder) #1
Issues & Pull Requests
ChibiOS
Plane
  • Release Update
Copter
  • Release Update
Rover
  • Release Update
(Craig Elder) #2
Attendee count (max): 24
UTC2305 - https://github.com/ArduPilot/ardupilot/pull/9631
  • Is this a good change?
  • Wrapper?
  • Makes code larger!
  • Having to go look at the wrapper sucks
  • On heliplane the indirection is actually useful
  • [10:07 AM] (Channel) MdB: If you are going to have to overload it fine, but I think the PR is alot more readable…
  • Randy thinks indirection for one line is not useful
  • The wrapper functions would make things slower but more compact
UTC2309 - https://github.com/ArduPilot/ardupilot/pull/8409
  • MdB has commented on the issue now
  • Tridge will go back through MdB’s comments now!
  • Randy’s keen for this one!
  • Parameters are one concern
    • Crash bug
    • Will constrain
  • [10:13 AM] (Channel) Naterater: Didn’t Tom say there is a unit that can do 100Hz GPS? Not worth supporting?
  • [10:14 AM] (Channel) MdB: Nate: Not that we support at this time, and we don’t poll that fast anyways
UTC2310 - https://github.com/ArduPilot/ardupilot/pull/9358
  • Thanks to Tom in absentia for fixing this up
  • Should get original bug submitter to come back and test this
UTC2318 - ChibiOS
  • Removing the NuttX builds
  • Progress update
  • Aiming to get rid of the NuttX build
  • Issue numbers are dropping!
  • Solved a nunber of issues
  • DSMX spectrum issue
  • Safety mask issue
  • Solo gimbal twitch puzzling and hard to track down
    • Will probably remove NuttX anyway on this one
    • Need to MitM the Solo gimbal cable to nut this one out
    • Does Philip have the relevant parts or the part numbers
    • Tridge tried some buffer-size changes etc etc and it didn’t help
    • Still a puzzle!
    • OreoLED drivers still not working
    • Tridge and Peter might get together this week with all the parts to nut this out
  • I2c fix
    • Thanks to yakk54colin
    • Probably worth backporting to the stable releases
    • Timeout i2c transactions
      • Never under NuttX
        • If a device locks up you never get your bus back
        • OTOH, a very slow device will still work
        • Yakk54colin has a device which is sometimes slow
          • 10s of milliseconds
      • Chibios will time out the transaction
        • We need to cycle the clock line to destick devices whose transaction has timed out
        • Device will hold sda line low forever if it doesn’t get clocked
      • LED on same bus as airspeed sensor possibly interfering by causing noise?
  • NuttX support to be removed next week?
    • Major churn
  • Waf on eclipse is working now!
    • Don’t need the px4 toolchain stuff any more
    • Use stuff straight from ARM consortium and eclipse project
      • Much newer version of eclipse!
      • Cygwin package is still painful
        • Having something prepackaged for this would be good
    • Can now target all boards
    • Can we build the 3.5 tree with this new setup?
  • Should we remove NuttX entirely from the tree or just make the compiles fail?
    • “px4-v3 has been removed, see <webpage> for details”?
    • Should we provide a get-out clause?
    • How hard of a switch do we want to make?
    • Maybe had a #error for a week or two?
    • How about Leonard and Paul and the like - are they ready for waf etc etc?
      • Leonard is, tridge helped him
      • Paul is, tridge helped him…
      • Randy might be the last hold-out?
        • Randy doesn’t think so
        • Jacob and Rob still use Make
    • Call For Testers - Final ChibiOS testing before NuttX is removed
  • Tridge wants half a page of warnings explaining what’s going on if someone tries a make / NuttX build
    • So a #error may not be sufficient
  • Randy wants to give more warning that things are going to die
  • Tridge was going to PR in a week
    • And discussion then
    • First PR would remove build options and submodules
    • Not remove the #ifdef px4 through vehicle code
    • Second stage to remove the _PX4 drivers etc etc and the #ifdef’d code
    • Need to do the submodule remove very, very carefully
      • It is a bit of an art
  • [10:43 AM] (Channel) LV: Just get a Banner on ALL ArduPilot sites and FB announcing the break from make and PX4 and linking to a wiki article
  • Randy will create a PR to #error
  • More advertising required!
    • Need a blog post and post that to facebook
  • LV thinks a banner on every page
    • Randy will patch the dev wiki
  • Should we remove the px4-v3 etc etc builds from the Wiki?
    • Tridge thinks yes
    • People using Copter 3.4.6?
      • Randy thinks deprecating
      • “Building with Make not recommended” already there
  • While we’re at it - we should kill the APM stuff from the Wiki
    • Long term
    • [10:49 AM] (Channel) Jani: we have still huge userbase of APM firmwares
    • [10:50 AM] (Channel) Jani: tens of thousands of downloads every month
  • Will discuss again in a week’s time
  • Craig thinks more visibility would be good
UTC2338 - documenting the supported boards
UTC0007 - Plane update
  • No new releases this week
  • Probably in next week or two
    • Benewake
    • Tridge is flogging Copter bits and Randy is flogging tridge’s bits
  • Will get differential spoiler stuff in in the next 3.9 point release
UTC0008 - Randy and Copter
UTC0011 - Randy and Rover
  • Rc2 will come out in next few weeks
  • https://www.youtube.com/watch?v=RRjOyaj2hNk
    • Using Cartographer
  • Next thing to focus on is the timing between companion computer and flight controller
  • Most bits are there
    • AP_RTC
    • Need to align the clocks!
    • ROS stuff needs to know when our IMU data was generated
    • ROS should be aligning clocks on the same way we do for input
    • [11:15 AM] To Weekly devcall: We don’t drift the clocks IIRC. tridge’s stuff doesn’t need it.
    • [11:16 AM] To Weekly devcall: "determining age"
    • [11:16 AM] To Weekly devcall: Rather than "aligning clocks"
  • We assume they are timestamping correctly
  • We assume uart timing jitter
  • We assume some sort of processing lag
  • We need the “glass time”, not message sending time!
  • ROS is spitting out error because we’re not responding quickly enough on timesync messages
UTC0020 - back to NuttX builds
UTC0029 - OlliW’s stuff is now being made by Jani
  • Will send some to tridge
  • Firmware is closed-source
    • No reason given
    • Bare-metal?
  • Schematics are available
  • Compiled binaries
  • New BetaCopter release
    • Jani would like to see patches come back
  • Tridge would be happier with firmware available
    • Not useful for tinkering as is
    • Need the source or new firmware
  • Stm32f103
    • Could probably run ChibiOS on it
    • E.g. io controller
    • Has a bootloader
    • Can update over uavcan
    • Could be a really, really useful tool with fiddleable firmware!
  • Still great to have without the firmware source
    • But better with
UTC0038 - https://github.com/ArduPilot/ardupilot/pull/8397
  • Tridge will rebase and have another look
UTC0040 - KDE CAN
  • FF will look again on Thursday
