Dev Call Feb 4 2019 2300 UTC
Issues & Pull Requests
Plane
Copter
Rover
GSOC
Attendee count (max): 19
Pre-Agenda:
  • Run 3 EKFs of same type?
    • Logging is a problem
    • But should work OK past that
  • Using extra CPU
    • How do we use extra CPU we’re now getting on e.g. H7s
      • Haven’t we got this on Linux already?
        • Linux doesn’t offer high loop rates
          • E.g. SPI rates
            • Call overhead
    • Should we bump Copter loop rate up from 400?
      • Maybe 750?
        • Stay below 760 for crappy lsm
      • Can’t run faster than your slowest gyro
      • May be stability advantage on small Copters
      • Easier tuning, apparently, from betacopter reports
        • Tridge needs to talk to Leonard
          • True for our arch?
    • Neural network?
UTC1107 - https://github.com/ArduPilot/ardupilot/pull/10408
  • Randy to look at
UTC1115 - https://github.com/ArduPilot/ardupilot/pull/10407
  • Merged
UTC1119 - https://github.com/ArduPilot/ardupilot/pull/10385
UTC1121 - https://github.com/ArduPilot/ardupilot/pull/10378
  • Do we merge this?
  • Prove no harm?
  • Thinking and working required before this is merged
  • Do we merge it and fix things later?
  • Go off MINIMISE_FEATURES
  • Some code formatting stuff
  • Not completely obvious it does nothing when not enabled
  • Tridge will take this, but it will almost certainly bitrot
UTC1125 - fix support for external nav
  • https://github.com/ArduPilot/ardupilot/pull/10374
    • Adds support for input of external positioning
  • AL: why so many changes
  • RM: found some issues with integration of external navigation integration
  • Rebased recently
  • This has been retested
    • Found some problems
      • Fine for a while then loses the plot
  • Gives position and quaternion attitude estimate
    • Fusing (or not!) of the attitude estimate may be the problem
    • Could be “local” compass heading issue
  • Fail in simulation?
  • Could use one of the ekfs to loop back into another to test
    • So ekf3 uses ekf2 as an external source
    • Logs would give you a good way to validate it
    • Would need to add lag
  • Will run extended test in SITL to see if it replicates
UTC1133 - funding for EKF development?
  • Randy has been trying to get to some PRs
    • But feels underqualified
  • We fund a bugmaster
    • Perhaps we should fund some ekf dev work?
  • Will talk about it at dev conference
UTC1135 - AP_HAL_ChibiOS
  • https://github.com/ArduPilot/ardupilot/pull/10363
  • Timer issues
  • Drama in gitter channel
  • Pin mappings for aio different to the non-aio board
    • New hwdef?
  • Happens in other boards too
  • Seen Betaflight motor-ordering PR?
    • Betaflight vs dji vs ardupilot
    • We chose the pinouts so quadx with default motor ordering would work out of the box
      • But when your pins are in the corners of your boards next to the motors, it’s important to use those pins for that motor
      • Should follow silk-screen ordering
  • Incorrect silk-screens are out there.
  • Pinouts change between different versions
  • Maybe hwdef.dat should allow setting of frame-type-default
    • E.g. set to betaflight-x on this hwdef
    • Already some people flying these boards
      • With patch as-is we’d have people crash
        • If we use the frame-type defaulting then things should still work
          • Only works for X
            • Not v or h
  • Will need to warn Plane users on upgrade
    • Modern ESCs should not initialise, but we need to warn
  • Currently our servo outputs don’t match the silkscreen
    • We are going to match the silkscreen where possible
    • If two boards with different silkscreens then two different hwdefs
  • Need to get three patches in:
    • Kaktute f4/f7 patch, this motor-ordering PR and a patch for #ifndef HAL_DEFAULT_FRAME_TYPE etc
    • Tom and Josh will look at this
    • Need to be careful to avoid changing the timers
      • Pin number and timer number don’t change
      • Change things in parentheses
    • https://github.com/ArduPilot/ardupilot/blob/master/ArduCopter/Parameters.cpp#L367
      • defaulting-defines on config.h
      • Hwdef can then override the frame type
      • Set frame-type to 12 for kakute (blheli ordering)
  • [10:51 AM] (Channel) RandyMackay: it depends on the drone model/controller.
If we’re speaking RTF models like the M600 / M210, these are special. On the S900/S1000 motor order is a non issue when using ardupilot
  • RandyMackay: When asked why it was a “non-issue” for DJI, Luis replied, the motor controls are located on a small connection board, so it’s just a very simple matter of swapping a few jst plugs
UTC1152 - https://github.com/ArduPilot/ardupilot/issues/10360
  • Tridge, Peter and Jacob to look at it
  • Badges would be good.
    • Anybody done it?
    • Jacob will talk to William
UTC0004 - plate update throttle mix
  • Nice piece of work
  • One transition case that needed looking at….
  • Will put this in and mark it as needing backport
UTC0006 - https://github.com/ArduPilot/ardupilot/pull/10314
  • Merged!
UTC0008 - https://github.com/ArduPilot/ardupilot/pull/10132
  • Once MdB and Peter are happy it can go in
  • Peter explained idea about “dirtying” messagewriters so they run again
UTC0011 - https://github.com/ArduPilot/ardupilot/pull/10021
  • Tridge isn’t quite ready to review this yet
UTC0012 - https://github.com/ArduPilot/ardupilot/pull/9240
  • Configurable waypoint speed
  • stale?
  • Devcall removed
UTC0013 - partner’s call moved to next week
UTC0016 - Onion update
  • Never going to go in if tridge doesn’t test it
  • Waiting on tridge
UTC0018 - learn throttle trim
  • Lots of implications within TECS
UTC0020 - Randy and copter update
  • Copter-3.6 went out for beta testing
    • RSSI indicator for ChibiOS boards in 3.6
    • Parameter description changes
    • Some bugfixes
    • Skipping-first-spline-waypoint fixed
    • Dt calculation was incorrect 2/3ms issue
    • Rc override fix
  • Some 3.6 issues remaining
    • https://github.com/ArduPilot/ardupilot/issues/9498
    • Matek 405 logging not working
      • Working for iampete
    • Compass not working on some board?
      • Something to to with rc parsing?!
    • Sumd protocol not working?
      • Graupner
      • Never worked before
      • We do claim it works now…
UTC0024 - Rover update
  • 3.5.0rc2 went out for beta testing
  • Rover-3.5.0-rc2/-rc3 is available for beta testing
  • Nobody has complained about anything
  • One bug Jaime found
    • Tiny turns would give a divide-by-zero
    • Is_zero is not always sufficient, it turns out!
      • Perhaps it was just misplaced, as the variable was munged before being used as a denominator
  • Probably no -rc4
  • More documentation on Wiki on ROS stuff
    • http://ardupilot.org/dev/docs/ros-rviz.html
      • Little 3D viewing tool for ROS when it is building up a map
    • Next step is to add some navigation
      • Jaime’s been doing some work on that
      • Offload high-level navigation to ROS?
UTC0028 - https://github.com/ArduPilot/ardupilot/pull/10379
  • RPM implementation for Rover
UTC0032 - GSoC update with Jaime
  • Project Application deadline Feb 6
    • Will get application in soon
      • Same mentors as last time and adjust later
  • http://ardupilot.org/dev/docs/gsoc-ideas-list.html
    • Look at it!
  • Emphasis on iterating existing code
    • So our devs know what they’re talking about!
    • More likely to make it into master
  • https://summerofcode.withgoogle.com/how-it-works/#timeline
    • March 25th starts application period
    • April 9 to May 6 is application review period
    • May 6 student projects are announced
    • Dev period starts May 27 to Aug19th
  • Randy will nudge our website a little
