Attendee count (max): 23
UTC1102 - EKF initialised flag
- https://github.com/ArduPilot/ardupilot/pull/13515
- Need to look at the associated mavlink PR…
- Adds ekf-uninitialised to status flags
- GCS can now report the EKF as not-ready-yet
- Logging needs to be fixed
- This can be merged once it is rebased
- [10:06 AM] (Channel) MdB: We should add comments on this type of static assert detailing why it was critical in the future, but thats not an item for this PR
UTC1106 - https://github.com/ArduPilot/ardupilot/pull/13417
- Two almost identical templates, one now being removed
- merged!
UTC1109 - https://github.com/ArduPilot/ardupilot/pull/13065
- Prevent land failsafe going back to do-land-start
- Whitespace fixes?
- Can be merged after whitespace fixes
UTC1112 - https://github.com/ArduPilot/ardupilot/pull/12889
- Add param set/get
- Great capability
- Find call looks scary
- [10:13 AM] To Weekly devcall: Maybe need to keep a “handle” on a parameter?
- Holding semaphores in scripts is scary stuff
- Any scary stuff in terms of race conditions when we register stuff e.g. quadplane?
- Probably not ATM
- merged!
UTC1117 - https://github.com/ArduPilot/ardupilot/pull/12629
- Compass ordering improvements
- Randy tested it and couldn’t find any bugs in flight code
- Also tested the MissionPlanner screen and found plenty of issues
- MO is chasing
- Interesting type-safety trick
- More comments would be nice
- And some variable naming
- But this is something we can use in other places
- External interface to compass library isn’t changed all that much
- 1st/2nd compass you just ask for it
- Behind the scenes it uses a priority scheme to return an object
- Could get interesting from a logging perspective
- Only in parameters, not in log messages
- Reboot required for parameters to have effect
- Need to be tagged @RebootRequired
- On boot parameters are reordered
- Casting needs to be fixed
- Should be merged mid-week
UTC1126 - https://github.com/ArduPilot/ardupilot/pull/13583
- This probably won’t play well with dynamically inserted SD cards
- Could possible create the directory when an SD card is inserted
- Having a SIM parameter which disables file system access would be good
- So you can start simulation without storage available, fail to arm
- Closed as breaks dynamic insertion
UTC1131 - https://github.com/ArduPilot/ardupilot/pull/13576
- Don’t recalculate stuff when not required
- Merged!
UTC1134 - https://github.com/ArduPilot/ardupilot/pull/13572
- Removed unused variables
- Merged!
UTC1135 - https://github.com/ArduPilot/ardupilot/pull/13564
- Reduce memory usage associated with sandboxing
- 8500 less bytes ram for trivial scripts
- And makes CubeBlack smaller
- Don’t embed romfs file
- Hacking lua sourcecode to remove stuff
- When hacking - comment or #ifndef?
- Less likely to conflict
- Will move to next version of lua and do this a bit better
- Was tested on real hardware
- merged!
UTC1137 - https://github.com/ArduPilot/ardupilot/pull/13558
- Shell completion tidy
- Merged
UTC1139 - https://github.com/ArduPilot/ardupilot/pull/13557
- Allow scripts to do prearm checks
- One string for failing external authoriser
- Only first failing authoriser gets to whinge
- Like GPS library
- High memory cost for doing all authorisers
- [10:42 AM] (Channel) MdB: bitsets do 32 for free this is why I’m so keen on it
- MdB wants to have a closer look
- Tridge wants string-per-one
- Arming check for allocation-has-failed?
- Add arming check for sanity check on mission
- MdB will merge after he’s looked at it
UTC1148 - https://github.com/ArduPilot/ardupilot/pull/13547
- REPL for LUA
- Found a way to reuse the ftp protocol
- It’s in MissionPlanner beta
- Mav-cmd-enum to start/stop repl
- Will be used for restarting scripts
- Need a restart button for REPL
- MP may or may not have this…
- AP::FS stuff needs some help
- The eexist is odd
- Equals-stdin on load-buffer?
- Needs to be re-tested
- Can be merged after a rebase/valgrind
- Mavlink PR was merged
UTC1157 - https://github.com/ArduPilot/ardupilot/issues/13546
- Those are the same thing
- SYSID_SW_MREV
- Copter and Sub
- FORMAT_VERSION
- Plane and Rover and Tracker
- SYSID_SW_MREV
- Parameter conversion code would get a touch complex
- Some magic in the GCS to not load FORMAT_VERSION and SYSID_SW_MREV
- We’ll go to FORMAT_VERSION
- Good-first-issue
UTC0004 - https://github.com/ArduPilot/ardupilot/pull/13528
- Minimise-features
- Yes
- Future PR
- Tested on a real vehicle
- https://i.imgur.com/Kg4AAkm.jpg
UTC0008 - https://github.com/ArduPilot/ardupilot/pull/13498
- Fixed
UTC0014 - https://github.com/ArduPilot/ardupilot/pull/13482
- Hide parameters not used in AP_Periph
- Merged!
UTC0015 - https://github.com/ArduPilot/ardupilot/pull/13479
- Windows 7 still must be using cygwin
- Tridge is asking for changes
UTC0019 - https://github.com/ArduPilot/ardupilot/pull/13426
- Some minor changes and then it can be merged
UTC0022 - https://github.com/ArduPilot/ardupilot/pull/13237
- Merged!
UTC0023 - https://github.com/ArduPilot/ardupilot/pull/13067
- If we’re not armed we could set to false
- Merged!
UTC0030 - https://github.com/ArduPilot/ardupilot/pull/12905
- SITL webots enhancements
- Merged!
UTC0031 - https://github.com/ArduPilot/ardupilot/pull/12788
- Add sentence to readme
- Overstates the case
- Wiki needs fixing too
- https://www.google.com/search?client=ubuntu&channel=fs&q=software+capable+of+controlling+any+vehicle+system+imaginable&ie=utf-8&oe=utf-8
- Needs fixing in concrete5
UTC0037 - Plane 4.0 release
- New release!
- Now in sync with Copter
- 160-odd patches
- DNA server!
- Big milestone
UTC0038 - https://github.com/ArduPilot/ardupilot/issues/12547
- Copter 4.0.2
- Issues list is getting smaller!
- New Neopixel issue
- Probably just out of time to do stuff
- Peter Hall will try to duplicate
- EAMS lab report an issue
- Guided mode
- 3.6 only
- Auto -> guided
- Then a bunch of position targets with all zeroes in them
- Couldn’t recover in any other flight mode
- Including stabilize
- Lost attitude control
- NaNs?
- None visible
- NaNs?
- No issue yet
- Wp-nav-alt-min so vehicle takes off straight
- Don’t hold position
- Can get a drift-away
- EKF origin-vs-home could have affected it
- Can get so far away from target line it won’t progress along the line
- Will try to get back to line
- During period of climbing straight up it won’t try to get back to line
- If it gets blown too far from line then it won’t try to climb any more
- Won’t generally hit it, but a combination of parameters will do it
- Like 50m of wp-nav-alt-min, which is a lot
- Support load dropped off significantly now
UTC0050 - https://github.com/ArduPilot/ardupilot/issues/12509
- Rover release coming up soonish
- non-GPS-navigation work coming
UTC0051 - Crash following 'RCInput: decoding SBUS'
- On ground, set parachute inactive on the Companion Computer
- Externally visible state vs internal state?
https://github.com/ArduPilot/ardupilot/pull/10166/files
- Peter to revive this PR
UTC0103 - Reminder about open votes
- Support positions
- Calls for nominations for both positions
- Also for selection committee
- Two emails, slightly different subjects
UTC0104 - Close
