Dev Call Dec 17 2018 2300 UTC
Issues & Pull Requests
Common
  • AP_Periph work
  • NuttX removal
Plane
  • Onion Update
Copter
  • Release update
Rover
  • Release Update
Attendee count (max): 21
UTC2302 - https://github.com/ArduPilot/ardupilot/pull/10023
  • Merged!
  • Bisection for flight characteristic regressions coming
UTC2306 - slew rate limitting
UTC2308 - https://github.com/ArduPilot/ardupilot/pull/9844
  • Separate fixed wing landing radius etc
  • No MdB
  • MdB appears to have addressed tridge’s initial comments
    • Particularly for non-achieved stuff
      • Extra check added
  • merged!
UTC2309 - AP_Periph
  • PhillipK, Jani and tridge have been working on CANBus periperhals
  • Build target for AP which builds a firmware which isn’t ardupilot but is a peripheral firmware
  • Provides a CAN node
  • Initial target is for the little generic CAN nodes that Jani is selling
  • Hwdef to define pinout
    • Easily retargetable
  • Passthrough of i2c, spi, uarts
    • Appear in HAL as being local i2c etc buses
      • So existing drivers should just work
      • I2c remotely over CANBus…
        • That’s the plan, anyway
        • I.e. doesn’t use the remote-magnetic-field CAN messages
      • No new sensor drivers needed?
      • Won’t be able to share the device across multiple autopilots when remoting the bus like this
  • IO expanders, essentially
    • More functionality than existing CAN units as AP drivers are more full-featured
    • Pavel’s not a great fan of this way of doing things…
  • Currently just comes up and blinks LEDs
  • Allocation of node/bus ids?
    • Canbus parameters set via mavlink
  • Will probably need to delay bootup for compasses and the like so the remote devices are ready
  • Using Libcanard
    • Very easy to work with and nice
  • Still uses CAN messages, so interoperable with other CAN things on the same bus at the same time
  • Softserial
    • Coming at some stage….
    • F7 and F3 both support pin inversion
    • Softserial means no external inverter needed on F4
    • We already have some softserial decoders
      • The RC stuff, for example
      • Blheli passthrough too
      • Abstraction needed!
  • We have option bits on serials now
    • Swap RX and TX in software on F7….
      • Should be able to do ows easily
        • F4 should also be able to do this half-duplex stuff
  • PixRacer has internal inverter
  • Full support only on F7s for these serial options
UTC2328 - NuttX removal
  • Just ONE conscientious objector at the moment
  • Px4v2 no longer builds on master
  • ChibiOS builds fmuv2 no worries
  • CI failing for every PR
  • Could put effort into making v2 smaller again
    • But really just want to remove it
  • PR wasn’t rebased
    • So it didn’t fail CI
  • New landing stuff for Plane was the objection?
  • 8k a few months back when we disabled the bootloader on px4v2 and 1
  • Chewed through that…
  • Can we just pull the pin now?
  • A branch is probably going to have to happen until the conscientious objector can use ChibiOS
  • RM: a fair bit of time has gone by since we discussed this
    • Warnings went out a long time ago
    • Leonard’s moved over
    • MissionPlanner build has been solved
    • Randy has no concerns any more
      • How much of tridge’s time do we want to waste?
  • This is master, our playground for the next release
    • Tridge doesn’t want to do another release of Plane with NuttX supported
      • Confusing for users
  • No MdB on the call
UTC2335 - Plane onioning
  • Rebasing is hell for Tom ATM
    • Tridge could help
    • Might just restart instead
  • TP is off after a week
    • Hopefully get it done before then
UTC2336 - Randy and Copter
UTC2339 - Randy and Rover
  • Peter is looking at more message splitting
  • See Jaime’s video of Aion Robotics rover driving around using Cartographer
    • It’s great
    • And there’s documentation floating around for it on the Wiki!
UTC2344 - circling back around to NuttX
  • Need a decision!
  • Discussion / browbeating to happen
  • Will go in in next few days if no response can be had
UTC2346 - https://github.com/ArduPilot/ardupilot/issues/9372
UTC2354 - next meeting?
  • Probably not xmas morning….
  • 1st will be a “casual” meeting
    • No agenda as such
    • Probably lightly attended
  • Next official Jan7/8
  • Thanks everyone for all your work this year!
    • Vast amounts of stuff done!
  • Congrats to tridge on his new degree
    • Credit for the AP
