Dev Call Apr 29 2019 2300 UTC
Issues & Pull Requests
General
  • firmware download handling (new manifest code)
GSOC
Tracker
Plane
Copter
Rover
Attendee count (max): 17
UTC2304 - University of Maryland organ flight
  • Very cool and another first for ArduPilot
    *Congratulations to Ryan Henderson and the team at University of Maryland
UTC2307 - https://github.com/ArduPilot/ardupilot/pull/11195
  • Important related bugfix went in this morning
  • This one hasn’t been reviewed yet
  • Adds additional parameters for speed-scaling options
  • Bitmask for options
    • Boost for surface throws at low throttle
    • Changes default max gain goes from 5 to 2
    • Speedminspeedmax interpolates between plane and copter gains as a function of airspeed
    • Minimum value you can scale to (.2 / .4)
    • Reduces surface throws as throttle increases and tilt angle increases
    • All three options off by default
      • 3-bit bitmask
  • This seems to do other things as well
    • If statement based armed around outputs call
    • No tailsitter movement when disarmed?!
    • Will be fixed
  • Needs to be tested on real vehicles
  • Mostly tested in SITL
  • Debug code also looks a little odd
  • Style issues
  • Need to have same surface movements armed/disarmed
  • Intending for Peter Hall’s changes to affect quadplane?
    • But these changes only seem to affect tailsitter functions
UTC2309 - https://github.com/ArduPilot/ardupilot/pull/11110
  • Reinstate tailsitter roll limit
  • Bad rebase of the onion caused code loss?
  • Some sort of audit required to ensure we haven’t lost other code
    • Working out which commits may have been lost?
    • Last October?!
    • 2,500 commits since then
      • 192 in ArduPlane directory
        • Tridge will go back through the patches with any help he can muster
        • Servo jitter fixes
UTC2326 - https://github.com/ArduPilot/ardupilot/pull/11094
  • Merged!
  • Clang builds fixed!
UTC2330 - https://github.com/ArduPilot/ardupilot/pull/11017
  • Uavcan flow sensor
  • No Sid on call
  • Lots and lots and lots of patches
  • What’s the point of discussion here?
    • Randy’s keen to get this into master
    • Devcall was added 21 days ago
  • Would be nice if the patches were appropriately squashed
  • Devcalltopic removed
UTC2331 - https://github.com/ArduPilot/ardupilot/pull/10941
  • Need the signed/unsigned char thing fixes
  • Need to address Michael’s concern
UTC2335 - https://github.com/ArduPilot/ardupilot/pull/10443
  • Merged!
  • Was rewritten - delaying it was correct!
UTC2337 - https://github.com/ArduPilot/ardupilot/pull/10409
  • Merging this will let GCS authors get on with generalising their code for upload/download
  • [9:46 AM] (Channel) LV: IMHO We must try to push fence sooner rather than later due to several regulatory stuff coming to law soon
  • Hopefully get this merged this week
UTC2346 - https://github.com/ArduPilot/ardupilot/pull/10402
  • Would like to get this governor code merged
  • It’s quite mature
  • Lots of rsc changes are hinging on this
  • When RPM is unhealthy it defaults to throttle curve
    • Depends on throttle curve
  • New subgroup of parameters
  • Already being flown by a considerable number of users on 3.6 Copters
  • Droop-speed governor
    • Moves reference according to load
    • Electronic version of a Woodward mechanical governor like on constant speed Plane and Copter motors for years
  • Randy would like to review it a bit more
  • https://github.com/ArduPilot/ardupilot/pull/10402/files#diff-9dac2836c888bb8d5d194c71ffc2e174R163
    • Array size assumption needs to be fixed
    • Won’t have effect if vehicle is flying
    • Some oddities commented that should be looked at
  • Initialisation of variables to zero
    • new() / static things don’t need zeroing
    • [9:57 AM] To Weekly devcall: Welll… not adding new ones, rather than removing old ones
    • [9:57 AM] To Weekly devcall: 'though removing old ones would have prevented this discussion :slight_smile:
    • Note that classic c / c++ says to zero things
      • But we’re trying to keep features on smaller CPUs so we want to save the bytes
UTC2348 - https://github.com/ArduPilot/ardupilot/pull/9506
  • Low-pass filter in Plane
  • Would want a reasonably high sink rate for Copter
  • Off by default
UTC0004 - https://github.com/ArduPilot/ardupilot/pull/11221
  • Making changes to the way downloads are handled
  • Scraped out of Michael’s binary repo old stable releases
  • Manifest will include those
  • Michael is changing MP to use the manifest
    • Will give you a list of firmwares that match the board
    • Fmuv5 boards shipping with px4 bootloader
      • No ways to distinguish the boards in the bootloader
  • Need to coordinate with Don so QGC gets done
  • http://ardupilot.org/dev/docs/bootloader.html
  • New bootloaders reboot a lot faster on watchdog reset
UTC0013 - lots of PRs being slowed down
UTC0017 - CubeBlack issue
  • Essentially resolved with new Plane and Copter releases
  • HW fault
    • Service Bulletin issued
    • Baro + 2 gyros + 2 accels on isolated board we
    • Vibration and heating over time
  • Remediations
    • If you lose an IMU then we can fly on the internal IMU if it is high enough quality
      • Clipping all the time is not good
  • CubeBlack adds boot checks that all sensors are there
    • No checks on the NuttX build
  • [10:19 AM] To Weekly devcall: Should we add equivalent checks for all boards - that all your internal sensors are actually present?
    • Sensors vary on e.g. fmuv3
    • Imagine non-CubeBlack board
      • Px4v3 doesn’t probe for external baros
  • Maybe add “required” to the hwdef?
    • Manufacturers do upgrade their sensor suite
      • Things won’t “just work”
        • But Philip has just declared he’s willing to put up with that so….
  • “Must find IMU on this chipselect line” might be a good check?
UTC0027 - GSoC update
  • Slots have been allocated
  • A couple of days until student selections are finalised
    • But we’ve done that
UTC0029 - Tracker release
  • Good feedback received
  • MissionPlanner isn’t loading correct firmware
    • Might be hard-coded Tracker stuff inside MP
  • Battery issue
UTC0031 - Plane release out
  • Remediations for Cube issue
  • Marco did a nice video
    • RC switch to lock the vehicle up
  • Septentrino updates went in
  • Retries to flash storage of parameters
  • Reduce chance of parameter reset on F4 boards
  • Microsd fixes on PixHack
  • Fixes power flags on second power input on fmuv5 so you see both supplies
UTC0034 - Copter update
  • Need to do releases of Copter and Rover with latest hardware fixes
  • CubeBlack is already out in Copter
    • But follow-on changes need to go in
    • 3.6.9rc1 later today
  • Rover later today too
  • Beta testing for a week or two
UTC0035 - navigation code
  • Randy’s planning on restructuring the navigation code
  • Navigation library at top which gives you roll/pitch
    • Attitude controller below that
  • In Rover you speed controller is at top and then your navigation controller then your steering controller
    • Will change to make it like Copter
UTC0036 - 3.7?
  • Have enough stuff to justify a 3.7 release
  • Randy wants to do more object avoidance stuff before 3.7
    • Stayout zones
    • Backing away from objects
  • Sometime in next couple of months
  • Bill and Chris want to do stuff on spool logic before 3.7 so Randy’s not the only hold-up
UTC0038 - Close
