Hello everybody, this is my first post, I couldn’t find a section/topic about writing/integrating custom drivers to support new EFI modules, so I am posting here, please redirect me if i did it wrong.
I wrote and now testing a code for parsing Telemetry data coming from FlyHenry’s EFI ECU,
It is not done via LUA scripting, but with a dedicated driver called AP_EFI_Serial_FH.
It is working correctly, parsing the FlyHenry’s serial telemetry data, converts data types, align ranges and injects results into ArduPilot’s stack… I have implemented the FlyHenry’s telemetry protocol on my own and replicated the way how variable forwarding was done for MegaSquirt2 and LUTAN ecu’s.
Now I want to use the reverse data path - TX line of the AP’s telemetry port to control EFI’s Ignition, Starter, ECO/MAXP for fuel mixture profiles and Throttle, as Henry’s telemtry protocol is auto-streaming and doesn’t require polling/requests it is anyway unused.
I want to fit a small MCU controller which will read the serial data coming form ArduPilot and control the EFI ECU - instead of having 4 separate PWM channels dedicated on these functions.
Can someone guide me, how to get those variables from the EFI_Serial driver context, if it is possible without modifying code of AP_ICE module… I need those few flags and one variable to be accessed from AP_EFI_SERIAL_FH::update() so i can send them on a regular time basis or immediately if there is a change. The goal is to fully control the engine only via Serial, leaving more PWM channels free, and to simplify wiring between AP and ICE.
Thank you in advance
Best Regards
