I have downloaded dataflash logs from CubePilot Orange.
I have transformed the .bin file into a .log file and I started analyzing data to perform my own analysis.
I tried to convert data into the correct unit of measure using multipliers.
I found that latitude and longitude of GPS message are 45 and 9 degrees approximately and they are coherent to my location. However, if I use the corresponding multiplier, I should multiply those values by 1e-7 (in FMT message the id corresponding to GPS is 87, then in FMTU, MultIds of 87 correspond to ‘F----0BGGB000–’ and the double GG are for latitude and longitude, which are referred to 1e-7 multipier). Is it correct?
Am I doing something wrong or there is an error in the log file?
