Custom Mavlink Mission Command
I have followed this guide to add a custom mavlink message: Adding a new MAVLink Message — Dev documentation
I am trying to create a mission command that has the same functionality as the script_time mission command, however I wish for the argument and timeout to be a static number; not set by the user. I want to create several of these mission commands so it’s easer for the user to setup a mission in the plan tab on MP.
All I’ve done so far is add an entry into the ardupilotmega.XML file for our custom command and I’ve added a case in AP_Mission.cpp’s case statement to handle setting the arguments and timeout to a static number.
I understand I need to build out more of the backend for arriving at the waypoint and handling the timeout, however, I assumed adding the mission to the XML file would allow Mission Planner to find the command and auto populate it by using Ctrl-f → manage command list by typing in the ID, but it doesn’t.
At what point in development will my command show up in Mission Planner or is my logic flawed?
I know its late, but any changes to firmware code won’t show up in mission planner, you will have to do changes in mission planner code for that.
you have 2 options:
  1. either just add the commands manually
  2. or read step 5 here
