Hi All,
So, I run the test with only one ESC, by mistake the protocol was set on 2 (MavLink2) and than suddenly telemetry showed out on the status tab but not in the log file. Next test, nothing.
I reverted the protocol to 16 and nothing. That’s when I lost it and as a last resort, down-graded BLheli FW to 3.2.6 and everything is working.
Hope it helps someone and thanks @smartdave and @xfacta for your help much appreciated !!!
Gal
The only time you want Auto Telemetry on is when not using Dshot as the ESC protocol. If you are using PWm or Oneshot you will need Auto Telemetry turned on
@andyp1per
I was just try to read BlHeli setting via CUAV v5 Nano FC using BlHeli 32.8.0.4 suite.
CUAV v5 Nano configured as MOT_PWM_TYPE = 6 (Dshot600) and SERVO_BLH_AUTO =1.
I can see the message tap in mission planner that configured for DSHOT as below picture RC OUT:Dshot 1-4 PWM 5-11 and all esc connected to 1 to 4 on main port of the v5nano.
here my Question is if BLHeli32 Suite is only to configure for ESC shall i connect via CUAV V5+ and configure it.
Then those esc I can use it for CUAV v5 Nano for flying?
Motor test worked on CUAV V5 Nano then why BlHeli Suite not working.
BlHeli suite accept only Beta firmware of the Ardupilot to configure the Esc ,so after configured ESC done can i reverse the Ardupilot firmware to stable version for flying?
