Hello every one. I want to use 2x CUAV C-RTK 9Ps for RTK ( one as base and one as rover) and I connect the base GPS to my laptop and the rover GPS to CUAV X7+ autopilot and the autopilot is connected to my laptop via FM30 telemetry (I can config the autopilot with FM30 transmitter)
The base GPS work correctly but it does not send the correction data to the rover GPS. I have it configured exactly like the ardupilot documentation site. According to the site, GPS status should displays RTK Float / RTK Fixed / 3D RTK but it displays 3D dgps.
Can anyone help me to solve this problem?
Try to talk with CUAV…
What ground station do you use? You should first check whether the hm30 air terminal is sending rtcm to the flight controller.
The “best” GPS modules can vary depending on your specific needs and applications. When evaluating GPS modules, consider factors such as accuracy, sensitivity, update rate, power consumption, size, and cost.
here you maybe find your gps module that is better than cuav c-rtk 9ps
You used a deceptive link, which pointed to the brick manufacturer.
