Hello Everybody,
Iam trying Secure boot support on CubeOrange
Following this steps in github page but the build file shows error like
tunga@tunga-desktop:~/ardupilot$ ./waf copter
Waf: Entering directory /home/tunga/ardupilot/build/CubeOrange' Checking for env.py env added DEFAULT_PARAMETERS=/home/tunga/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/CubeOrange/defaults.parm env added APJ_BOARD_TYPE=STM32H743xx env added USBID=0x2dae/0x1016 env added EXT_FLASH_RESERVE_START_KB=0 env added OPTIMIZE=-O2 env added BOOTLOADER_EMBED=1 env added ENABLE_DFU_BOOT=1 env added MAIN_STACK=0x600 env added BOARD_FLASH_SIZE=2048 env added APJ_BOARD_ID=140 env added CORTEX=cortex-m7 env added CHIBIOS_BUILD_FLAGS=USE_FATFS=yes MCU=cortex-m7 ENV_UDEFS=-DCHPRINTF_USE_FLOAT=1 CHIBIOS_PLATFORM_MK=os/hal/ports/STM32/STM32H7xx/platform.mk CHIBIOS_STARTUP_MK=os/common/startup/ARMCMx/compilers/GCC/mk/startup_stm32h7xx.mk env appended CPU_FLAGS=['-mcpu=cortex-m7', '-mfpu=fpv5-d16', '-mfloat-abi=hard', '-DARM_MATH_CM7', '-u_printf_float'] env added PROCESS_STACK=0x1C00 env added HAL_NUM_CAN_IFACES=2 env added EXT_FLASH_SIZE_MB=0 env added HAS_EXTERNAL_FLASH_SECTIONS=0 env added FLASH_TOTAL=1966080 env added ENABLE_CRASHDUMP=1 env added IOMCU_FW=0 env added HAL_CANFD_SUPPORTED=8 env appended APP_RAM_START=None env added BUILD_ABIN=True env added FLASH_RESERVE_START_KB=128 env added PERIPH_FW=0 env added WITH_FATFS=1 Padded 16 bytes for bootloader.bin to 50144 Embedding file bootloader.bin:/home/tunga/ardupilot/Tools/bootloaders/CubeOrange_bl.bin Embedding file hwdef.dat:/home/tunga/ardupilot/build/CubeOrange/hw.dat Embedding file io_firmware.bin:Tools/IO_Firmware/iofirmware_highpolh.bin [905/912] Linking build/CubeOrange/bin/arducopter [906/912] apj_tool build/CubeOrange/bin/arducopter Loaded binary file of length 4103112 Setting defaults from /home/tunga/ardupilot/libraries/AP_HAL_ChibiOS/hwdef/CubeOrange/defaults.parm Saved binary of length 4103112 [907/912] Generating bin/arducopter.bin [908/912] app_descriptor build/CubeOrange/bin/arducopter.bin Waf: Leaving directory
/home/tunga/ardupilot/build/CubeOrange’
Build failed
Traceback (most recent call last):
File “/home/tunga/ardupilot/modules/waf/waflib/Task.py”, line 348, in process
ret = self.run()
File “Tools/ardupilotwaf/chibios.py”, line 297, in run
desc = struct.pack(‘<IIII76s’, crc1, crc2, len(img), githash, sig)
error: argument for ‘s’ must be a string
Can anyone please help me to solve this issue
Thanks in Advance…
