Hi everybody
2 days ago I had a crash with an easyglider 4 (pixracer + xrs frsky + pitot tube + gps)
suddenly I fbwa mode the plane started to spin and I was not able to recover
I suspect a bad COG (center of gravity)
Any idea ?
Adolfo
Hi everybody
Any idea ?
Adolfo
Update
Elevator is channel 3
During the spin RCIN & RCOUT are inverted
Strange
Did I tune something wrong ?
Thanks
Adolfo
Okay, so here is my guess. It goes without saying that I could be wrong.
So, you took off at 261s in Stabilize, full throttle and climbed to 110m.
At that point you had around 11m/s in airspeed.
Then, you closed the throttle all the way and witched to FBWA at 277s.
I assume you wanted to glide and started doing so at around 7.5m/s airspeed.
I’m not sure how slow this airframe can fly at.
Then, at 396.5s I think I see a tip stall. Signs:
Summing up:
George
first many thanks for your deep analysis.
I share your conclusion and recommendations
I will adjust the tuning and way of flying (no glide in FBWA)
nice regards
Adolfo
George
what is the software you are using for log analysis ?
Adolfo
It’s a MATLAB library we made for Ardupilot .bin log conversion to native MATLAB structures.
After that, it was all about plotting the right quantities at the right time frame.
You can find it here: https://github.com/Georacer/ardupilog
I had a similar phenomenon in ailerons.
Is aileron the same cause?
