I’m a newbie trying to using a Pixhawk 2.4.8 Autopilot to fly a quadcopter in Stabilize Mode. I have a confined space to fly the drone because I am only allowed to test it indoors presently so I don’t have a GPS fix.
When I arm the drone in APM Planner (on MacOS) , the propellers start rotating normally but the moment I throttle up slightly, the drone flies up without any user input and crashes into the ceiling, even with a very slight throttle applied.
I’m not quite sure what could be causing this and I initially thought that the issues could be the Pixhawk thinking that the battery was too low and triggering a failsafe but there doesn’t seem to be any indication of this in the only logs I could find. I have copied some of the relevant text if anyone is interested.
I am using a Taranis QX7 radio transmitter and an FrSky XSR receiver.
UAS:: Attempt to Arm System
[20190312 14:20:33.856 INFO ] - APM ARM System
[20190312 14:20:34.487 DEBUG] - Param: “GND_ABS_PRESS” : QVariant(double, 98490.1)
[20190312 14:20:34.489 DEBUG] - APM: Text Message rx’d “SUCCESS: Executed CMD: 400”
[20190312 14:20:34.489 DEBUG] - Severity: 0 text: “SUCCESS: Executed CMD: 400”
[20190312 14:20:34.778 INFO ] - Arming State Changed: ARMED
[20190312 14:20:34.779 DEBUG] - APM say: “armed”
[20190312 14:20:34.780 DEBUG] - UAS: new base mode 209
[20190312 14:20:34.780 DEBUG] - MODE: 209
[20190312 14:20:34.781 DEBUG] - “A|STABILIZED”
[20190312 14:20:37.850 DEBUG] - UAS: new system_status 4
[20190312 14:20:39.942 INFO ] - STATUS TEXT: 6 : “EKF2 IMU1 in-flight yaw alignment complete”
[20190312 14:20:39.943 DEBUG] - APM: Text Message rx’d “EKF2 IMU1 in-flight yaw alignment complete”
[20190312 14:20:39.944 DEBUG] - Severity: 6 text: “EKF2 IMU1 in-flight yaw alignment complete”
[20190312 14:20:40.064 INFO ] - STATUS TEXT: 6 : “EKF2 IMU0 in-flight yaw alignment complete”
[20190312 14:20:40.065 DEBUG] - APM: Text Message rx’d “EKF2 IMU0 in-flight yaw alignment complete”
[20190312 14:20:40.066 DEBUG] - Severity: 6 text: “EKF2 IMU0 in-flight yaw alignment complete”
[20190312 14:20:40.359 DEBUG] - HBD: Heartbeat stopped
[20190312 14:20:40.376 DEBUG] - HBD: Heartbeat started
[20190312 14:20:45.652 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:45.652 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:45.653 INFO ] - APM DISARM System
[20190312 14:20:45.901 DEBUG] - APM: Text Message rx’d “FAILURE: Failed CMD: 400”
[20190312 14:20:45.902 DEBUG] - Severity: 0 text: “FAILURE: Failed CMD: 400”
[20190312 14:20:46.644 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:46.644 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:46.645 INFO ] - APM DISARM System
[20190312 14:20:47.159 DEBUG] - APM: Text Message rx’d “FAILURE: Failed CMD: 400”
[20190312 14:20:47.160 DEBUG] - Severity: 0 text: “FAILURE: Failed CMD: 400”
[20190312 14:20:47.761 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:47.762 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:47.762 INFO ] - APM DISARM System
[20190312 14:20:47.995 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:47.995 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:47.996 INFO ] - APM DISARM System
[20190312 14:20:48.145 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:48.145 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:48.146 INFO ] - APM DISARM System
[20190312 14:20:48.298 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:48.299 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:48.299 INFO ] - APM DISARM System
[20190312 14:20:48.393 DEBUG] - APM: Text Message rx’d “FAILURE: Failed CMD: 400”
[20190312 14:20:48.394 DEBUG] - Severity: 0 text: “FAILURE: Failed CMD: 400”
[20190312 14:20:48.744 DEBUG] - APM: Text Message rx’d “FAILURE: Failed CMD: 400”
[20190312 14:20:48.745 DEBUG] - Severity: 0 text: “FAILURE: Failed CMD: 400”
[20190312 14:20:48.777 DEBUG] - APM: Text Message rx’d “FAILURE: Failed CMD: 400”
[20190312 14:20:48.778 DEBUG] - Severity: 0 text: “FAILURE: Failed CMD: 400”
[20190312 14:20:48.918 DEBUG] - APM: Text Message rx’d “FAILURE: Failed CMD: 400”
[20190312 14:20:48.919 DEBUG] - Severity: 0 text: “FAILURE: Failed CMD: 400”
[20190312 14:20:50.796 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:50.797 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:50.798 INFO ] - APM DISARM System
[20190312 14:20:51.077 DEBUG] - Param: “STAT_FLTTIME” : QVariant(int, 523)
[20190312 14:20:51.080 DEBUG] - Param: “STAT_RUNTIME” : QVariant(int, 53137)
[20190312 14:20:51.359 DEBUG] - APM: Text Message rx’d “FAILURE: Failed CMD: 400”
[20190312 14:20:51.360 DEBUG] - Severity: 0 text: “FAILURE: Failed CMD: 400”
[20190312 14:20:56.274 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:56.275 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:56.275 INFO ] - APM DISARM System
[20190312 14:20:57.109 DEBUG] - APM: Text Message rx’d “FAILURE: Failed CMD: 400”
[20190312 14:20:57.112 DEBUG] - Severity: 0 text: “FAILURE: Failed CMD: 400”
[20190312 14:20:57.331 DEBUG] - HBD: Heartbeat stopped
[20190312 14:20:57.366 DEBUG] - HBD: Heartbeat started
[20190312 14:20:58.495 DEBUG] - UAS: new system_status 3
[20190312 14:20:59.595 INFO ] - UASActionsWidget::armButtonClicked
[20190312 14:20:59.595 INFO ] - UAS:: Attempt to Disarm System
[20190312 14:20:59.595 INFO ] - APM DISARM System
[20190312 14:21:00.498 DEBUG] - Param: “MOT_THST_HOVER” : QVariant(double, 0.356568)
[20190312 14:21:00.499 DEBUG] - APM: Text Message rx’d “SUCCESS: Executed CMD: 400”
[20190312 14:21:00.499 DEBUG] - Severity: 0 text: “SUCCESS: Executed CMD: 400”
[20190312 14:21:00.501 INFO ] - Arming State Changed: DISARM
[20190312 14:21:00.502 DEBUG] - APM say: “disarmed”
[20190312 14:21:00.502 DEBUG] - UAS: new base mode 81
[20190312 14:21:00.502 DEBUG] - MODE: 81
