No, WSL runs on Ubuntu with Win 10 IP address 192.168.1.2, and RF8 on another PC with Win7 IP Adress 192.168.1.5. (Upgrade to Win 10 failed twice)
So you installed WSL on a Windows 10 machine, and RF8 is running on another computer under Windows 7.
If you can ping 192.168.1.5 from Ubuntu, SITL should connect to Realflight when you start it up.
I think I found the issue. I forgot that I had to install an Xserver for Windows:
This server needs to be running so that ArduPlane can display its console.
I start it up using the “Multiple windows” option:
and “no client” on the next screen, before running SITL. The reason I forgot it is that I added it to my Windows startup apps so that it starts when I log in to windows.
Installed VcXsrf and started as shown above, see it running in the Task-Manager.
But the same Warning: no config for frame (flightaxis:192.168.1.5) and stop a the same log Line. APM: EKF2…
And no infos in RF8, left, down.
I get that same warning here, so it’s not a problem.
Did you try to ping 192.168.1.5 from your Ubuntu window?
It says the video is private
No, how to do ?
By the way, must I start MissionPlanner in Windows bevor the Ubuntu SITL command or will this be done.?
In Ubuntu, type
ping 192.168.1.5
On my machine, it looks like this:
(base) 07:03:56 (pr-gsc-base) ~/linux_git/kd0aij/ardupilot/ArduPlane/Stryker_quad$ ping 192.168.0.100
PING 192.168.0.100 (192.168.0.100) 56(84) bytes of data.
64 bytes from 192.168.0.100: icmp_seq=1 ttl=128 time=0.328 ms
64 bytes from 192.168.0.100: icmp_seq=2 ttl=128 time=0.216 ms
64 bytes from 192.168.0.100: icmp_seq=3 ttl=128 time=0.243 ms
64 bytes from 192.168.0.100: icmp_seq=4 ttl=128 time=0.238 ms
^C
--- 192.168.0.100 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3002ms
rtt min/avg/max/mdev = 0.198/0.213/0.240/0.023 ms
It transmits packets about once per second, until you type ctrl-c to stop it.
If there is no connectivity to the URL you are pinging, you won’t see any of the “64 bytes from …” printouts.
Do you mean this with no connectivity?
Nothing to see after the command ping until Ctrl C.
Edit:
I tried the address 192.168.1.1, which is the standard gateway instead the Ipv4 and it works with ping.
But Ubuntu stops a the same line and no connection in RF8 to see.
Yes, that means there’s something wrong with the network. Either 192.168.1.5 is the wrong address, or something is configured wrong. On the machine running RealFlight, check that the IP address is correct. On my machine it looks like this:
@losawing @lorbass This is a plot from a SITL run with the BiWing JWL-065 airfoil and 2.5 degree top wing incidence. The red line is elevator (+1 up to -1 down), the green line is pitch (+1 is nose vertical, -1 is nose down) and the blue line is the magnitude of GPS speed (airspeed is zero in the log for some reason).
Note that the airspeed drops significantly when doing outside loops:
and when the airspeed gets very low, as at 21:31:46, the plane tumbles rapidly in pitch.
@losawing Does the airspeed drop like this with your real model when doing outside loops?
In Win 7 it looks like this:
But yes, there is something strange with the Net access.
Via the explorer, I can access all directories and files from both sides.
When I want to safe files from BlackPC (RF8) to Charly (SITL) I can’t see all directories.
Something bad configured with the “homeNet” which seems not to exist on Win 10.
Here the explorer view of RF8 side.
I deleted the home Network and now both PC’s are listet under Network.
And I tested ping with the ip adresse 192.168.1.5 as indicated in the print out of the Win7 PC and again, no 64 bytes from listed.
Could it be a setting in your router? I don’t know much about network configuration on Windows or Linux, and I don’t recall having to do anything special when I was using two machines connected to the same switch.
Airspeed ang gps speed look very normal. Airspeed is low around 45 ° right before outside loop end.
From the pilot point of view, the plane behavior is exactly the one of an acro plane, no lag, no limitation. Just the trajectory is much much easier to keep as gyros take care of roll and yaw.
I would say clean acro is so easy !!!
A huge step forward. I seems that we could win
I installed RF8 on a other PC with Win 7 Home Premium, Ping works as described and I saw the often desired: Connected. In the Ubuntu is the feedback line per line to see when I move the mode switch.
But the BiWing can’t be loaded in RF8 and therefore not be selected.
2 messages: file … succesful imported ( in green color)
…can’t be imported does not based on a nonexistent model. (in red color)
The same message with another model: SkyCat…
On the other PC it was possible.
2 more questions:
- how to see MissionPlanner?
- how to import the params into a directory of Ubuntu?
Great! That is very encouraging.
In RealFlight, you have the option to export either a “variant” or “entire model”, and the one you’re trying to import must be a variant of a model you haven’t yet imported.
The “BiWing_JWL065_EA.RFX” here:
should be a complete model and the file “BiWing.parm” are the parameters to use.
The readme file there has a partial description of the models and parameters.
You can download the RFX files using a web browser by clicking on them individually, then pressing the download button. The parameters file can be opened directly in a web browser and copy/pasted. You can also download the entire repository by going here: https://github.com/ArduPilot/SITL_Models and clicking the green “clone or download” button.
I don’t use MissionPlanner with SITL, but I think it might connect automatically if you start it up after getting SITL going.
Yes, it sits on the green grass.
I’v marked the 1300 lines of params, and then copy paste into the editor. Safed as BiWing.param.
I think there is a better way? Will try next time the clone way.
Now, how put I this file into Ubuntu?
In Ubuntu you can easily clone the SITL_models repo like this:
git clone https://github.com/ArduPilot/SITL_Models.git
When you type that command in your home directory, it will create a clone of the repository at ~/SITL_Models. (where ~ represents your home directory)
Once that is done, you will find the BiWing files at
~/SITL_Models/RealFlight/markw/Tailsitters/CopterTailsitters/BiWing/
and you can copy the parameter file to your ArduPlane/BiWing directory for convenience in loading the parameters.
At the mavproxy prompt after you start SITL, you can then type
param load BiWing.parm
reboot
to load the parameter file and reboot. You will probably have to ctrl-C (kill) the mavproxy/SITL window and restart before the parameters will be properly loaded.
To check whether the parameter load has worked properly, type
param show q*
If you see lots of parameters starting with “Q_”, you should be ready to fly. If not, type ctrl-c to shut SITL down, then start it up again. Repeat the “param load” command and “reboot” then recheck to see if you have all the Q_ parameters loaded.
If that doesn’t work, we’ll complain to @peterbarker
Now cloned and viewed in the directory.
I think the command in Ubuntu is now: cp BiWing.parm …
but I’not shure how to continue with the target. May be wrong and then never to find.
In that directory you would type
cp BiWing.parm ~/ardupilot/ArduPlane/BiWing
Looks like you just forgot the “~/” at the front of the path.
auto-completion is useful for this sort of thing; in that directory try typing
cp Bi<tab><tab>
where <tab>
represents the tab key
The first tab auto-completes until there are multiple possibilities, and the second display the filenames that match. You could then type in some more of the filename and tab again to finish the auto-completion.
