I’m helping a client with a drone that is a bit on the heavy side, and is oddly shaped, but has flown before and was stable and predictable.
It’s worth mentioning that this drone PID values are real steep:
ATC_RAT_RLL_P 0.385
ATC_RAT_RLL_I 0.5
ATC_RAT_RLL_D 0.01
ATC_RAT_RLL_IMAX 2.1
ATC_RAT_RLL_FILT 20
ATC_RAT_PIT_P 0.755
ATC_RAT_PIT_I 0.64
ATC_RAT_PIT_D 0.013
ATC_RAT_PIT_IMAX 5.144
ATC_RAT_PIT_FILT 20
ATC_RAT_YAW_P 0.8000001
ATC_RAT_YAW_I 0.1
ATC_RAT_YAW_D 9.49949E-11
ATC_RAT_YAW_IMAX 0.221
ATC_RAT_YAW_FILT 5
Those are the values that were used with this drone in its last 10+ flights, and it flew real well.
Unfortunately, it had a bad crash and although nothing has been broken, it’s not flying properly anymore.
On stabilize it took off okay, roll and pitch are normal. But yaw causes it to drop in altitude.
On position hold - The same behaviour but after I stop yaw-ing the drone goes back to it’s original altitude.
On the last couple of flights it has worsen - On stabilize, for same throttle value the drone took off to about 6m, hovered for about 2 seconds, then dropped in altitude until reaching the (soft) ground. A log of one of these flights is attached. (Note: I believe it wasn’t ground effect, since the drone hovered for a bit, then dropped)
2017-03-21 13-29-28.bin (193.0 KB)
Does this sound familiar to someone?
Help with this issue is appriciated,
Thanks
NItay
