Copter Landing with Rangefinder - Do I need Terrain Following?
Can I use a rangefinder to get accurate altitude data for landing a copter?
I can only find rangefinder references in the documentation associated with Terrain Following.
I do not think I need Terrain Following, just altitude control like the barometer would have done.
It appears from the documentation that if you set RNGFND_MAX_CM to a value within the rangefinder’s capability it will switch from the barometer to the rangefinder below that altitude.
Is this true?
Thanks,
Paul
