Copter-4.4.2 has been released as the official version for multicopters and traditional helicopters. The changes vs 4.4.1 are in the ReleaseNotes and copied below.
- Autopilot related enhancements and fixes
- BETAFPV-F405 support
- MambaF405v2 battery and serial setup corrected
- mRo Control Zero OEM H7 bdshot support
- SpeedyBee-F405-Wing gets VTX power control
- SpeedyBee-F405-Mini support
- T-Motor H743 Mini support
- EKF3 supports baroless boards
- GPS-for-yaw allows base GPS to update at only 3Hz
- INA battery monitor supports config of shunt resistor used (see BATTx_SHUNT)
- Log VER message includes vehicle type
- OpenDroneId option to auto-store IDs in persistent flash
- RC SBUS protection against invalid data in first 4 channels
- Bug fixes
- BMI088 IMU error value handling fixed to avoid occasional negative spike
- Dev environment CI autotest stability improvements
- OSD correct DisplayPort BF MSP symbols
- OSD option to correct direction arrows for BF font set
- Sensor status reporting to GCS fixed for baroless boards
Special thanks to our beta testers and those devs who contributed to this release!
