Copter-4.2.0 has been released as the official/stable version and can be downloaded and installed using MP or QGC (or you can manually download the .apj file from firmware.ardupilot.org)
Because of the built-in parameter upgrade feature, there should be no need to backup and restore your parameters as part of the upgrade. If you find you later need to revert to 4.1.x, please use MP’s Install Firmware screen’s “All Options” link or manually download the 4.1.x binary from firmware.ardupilot.org.
Warnings:
- Some setups using BLHeli_S ESCs may not arm or spin. If you notice problems with BLHeli_S ESCs please revert to 4.1.5 and wait for 4.2.1 which we hope will resolve these issues.
- Telemetry radios that do not understand MAVLink2 may fail to work unless SERIALx_PROTOCOL is set to “1”.
- If GPIO pins (used may be used for buttons, camera triggers, relays, etc) do not work, the issue is likely that the appropriate SERVOx_FUNCTION parameter must be set to -1. Please see this wiki page for more details.
- Precision landing may change the vehicle’s heading if it loses sight of the target and repositions itself. These “retries” can be disabled by setting PLND_RET_MAX = 0
The long list of changes vs 4.1.5 are in the ReleaseNotes and copied below. For those who were involved with beta testing, this version is exactly the same as the last release candidate (-rc4).
- AHRS/EKF improvements
a) EKF startup messages reduced
b) GPS<->Opticalflow automatic switching improved (see ahrs-source-gps-optflow.lua script)
c) LORD Microstrain CX5/GX5 external AHRS support
d) ModalAI VOXL non-GPS system supported (set VISO_TYPE=3, uses ODOMETRY mavlink msg) - Control and flight mode enhancements
a) Acro max rate params renamed and improved (see ACRO_RP_RATE, ACRO_Y_RATE, PILOT_Y_RATE, PILOT_Y_EXPO)
b) Airmode NOT enabled when arming with switch (see ACRO_OPTIONS and “ArmDisarm with AirMode” RCx_OPTION)
c) Auto and Guided support pausing (uses DO_PAUSE_CONTINUE mavlink command)
d) Auto supports up to 100 DO_JUMP commands on high memory boards
e) Autotune reporting improved (less spam, prints final tune)
f) Delay removed when waypoints are very close together
g) FLIGHT_OPTIONS to release gripper on thrust loss
h) Follow mode supports FOLLOW_TARGET message
i) ForceFlying auxiliary switch allows pilot to disable land-detector
j) Guided mode acceleration target support
k) Guided mode logging of targets improved (GUID msg split into GUIP, GUIA)
l) Harmonic notch filter on more than four motors
m) Land mode pilot controlled repositioning max speed reduced (also affects RTL and Auto)
n) Loiter mode ignores ATC_SLEW_YAW parameter
o) Pause and continue support (GCS changes are still pending)
p) Precision landing improvements esp when using PLAND_EST_TYPE = 1/KalmanFilter
q) RTL’s safe altitude (RTL_ALT) increased 85km (was 325m)
r) Simple mode heading reset via auxiliary switch
s) Sport mode deprecated
t) SURFTRAK_MODE allows disabling surface tracking in Loiter, AltHold, etc
u) Turtle mode (allows righting a copter while on the ground)
v) Waypoint navigation will make use of maximum waypoint radius to maximize speed through corners - Custom build server support (see https://custom.ardupilot.org)
- Lua scripting improvements
a) ahrs::get_location replaces get_position (get_position still works for now)
b) Auto support for NAV_SCRIPT_TIME commands (Lua within Auto)
c) Frame string support (allows scripting based frame to display custom description after startup)
d) Parameter support (no need to always use SCR_USERx)
e) Servo output control by channel number (previously was only possibly by specifying the SERVOn_FUNCTION value)
f) Scripting heap size increased to 100k on F7/H7
g) Script logged to onboard log (can be disabled by setting SCR_DEBUG_OPTS) - New autopilots supported
a) AirLink
b) BeastF7v2, BeastH7v2
c) FlyingMoon F407 and F427
d) JHEMCU GSF405A
e) KakuteH7, KakuteH7Mini
f) MambaF405US-I2C
g) MatekF405-TE
h) Matek F765-Wing-bdshot
i) ModalAI fc-v1
j) PixC4-Jetson
k) Pixhawk5X
l) QioTekZealotH743
m) RPI-Zero2W
n) SPRacingH7 Extreme
o) Swan-K1 - Safety improvements
a) Button, Relay and RPM GPIO pin conflict pre-arm check improved
b) Dijkstra’s avoidance performance improvements including converting to A*
c) Motor PWM range always uses MOT_PWM_MIN/MAX (if these are not set, they are defaulted to RC3_MIN/MAX values)
d) Parachute option to leave servo in open position (see CHUTE_OPTIONS parameter)
e) Parachute released arming check added
f) Pre-arm check of IMU heater temp
g) Pre-arm check of rangefinder health
h) Pre-arm check of throttle position skipped if PILOT_THR_BHV is “Feedback from mid stick” - Sensor driver enhancements
a) ADIS16470, ADIS16507 and BMI270 IMU support
b) Airspeed sensor support (reporting only, not used for estimation or control)
c) AK09918 compass support
d) Battery monitor supports voltage offset (see BATTx_VLT_OFFSET)
e) BATT_OPTIONS supports sending resting voltage
f) Benewake TFMiniPlus I2C address defaults correctly
g) Buzzer can be connected to any GPIO on any board
h) Compass calibration (in-flight) uses GSF for better accuracy
i) CRSFv3 support, CSRF telemetry link reports link quality in RSSI
j) Custom compass orientation for DroneCAN compasses
k) Cybot D1 Lidar
l) DroneCan (aka UAVCAN) battery monitors support scaling (see BATTx_CURR_MULT)
m) DroneCan (aka UAVCAN) GPS-for-yaw support
n) DShot uses narrower bitwidths for more accurate timing (allows BLHeli BlueJay to work)
o) Electronic Fuel Injection support incl Lutan EFI
p) FETtecOneWire resyncs if EMI causes lost bytes
q) IMU heater params renamed to BRD_HEAT_xxx
r) INS_NOTCH parameters renamed to INS_HNTC2
s) Landing gear enable parameter added (see LGR_ENABLE)
t) Lightware SF40C ver 0.9 support removed (ver 1.0 and higher still supported)
u) Matek H743 supports ICM42688
v) Maxbotix serial sonar driver support RNGFNDx_SCALING parameter to support for varieties of sensor
w) MPPT solar charge controller support
x) MTK GPS driver removed
y) Optical flow in-flight calibration
z) Ping200x support
aa) Proximity sensor min and max range (see PRX_MIN, PRX_MAX)
ab) QSPI external flash support
ac) uLanding (aka USD1) radar provides average of last few samples
ad) bUnicore NMEA GPS support for yaw and 3D velocity - TradHeli enhancements
a) Attitude control default gains improved
- ATC_RAT_RLL_FF, _I, _IMAX, _ILMI, _FLTT
- ATC_RAT_PIT_FF, _I, _IMAX, _ILMI, _FLTT
- ATC_RAT_YAW_IMAX, _FLTT
b) AutoTune mode
c) Collective setup (users will be forced to setup new collective parameters)
d) Rotor Speed Controller Internal Governor improvements (users required to retune governor)
e) Rotor Speed Controller Cooldown timer added for ICE and turbine engines
f) _VFF params renamed to _FF - Other System enhancements
a) Board ID sent in AUTOPILOT_VERSION mavlink message
b) Compass calibration stick gestures removed
c) DO_SET_CAM_TRIG_DIST supports instantly triggering camera
d) DJI FPV OSD multi screen and stats support
e) GPIO pins configured by setting SERVOx_FUNCTION to -1 (also see SERVO_GPIO_MASK. BRD_PWM_COUNT removed)
f) GPIO pin support on main outputs on boards with IOMCU
g) GyroFlow logging (see LOG_BITMASK’s “VideoStabilization” option)
h) Firmware version logged in VER message
i) Log and monitor threads stack size increased
j) SD card format via MAVLink
k) Serial port option to disable changes to stream rate (see SERIALx_OPTIONS)
l) VIBE logging units to m/s/s
m) Vibration failsafe disabled in manual modes - Bug fixes
a) Arming checks ignore SERVOx_MIN, MAX if setup as GPIO pin
b) Auto and Guided mode takeoff alt fixed if taking off from below home or frame set to absolute (aka AMSL)
c) Auto mode CONDITION_YAW command completion fix
d) Auto mode infinite loop with nav commands that fail to start fixed
e) AutoTune disables ATC_RAT_xxx_SMAX during twitch (SMAX may limit gains to reduce oscillation)
f) Battery remaining percentage fixed when using Sum battery
g) BeastH7v2 BMI270 baro support
h) Blended Z axis accel calculation fix when not using first IMU
i) BLHeli passthrough reliability improvements
j) Compass learning (inflight) fixed to ignore unused compasses (e.g. those with COMPASS_USE = 0)
k) DShot reversal bug with IOMCU based boards (see SERVO_BLH_RVMASK)
l) EKF optical flow terrain alt reset fixed (large changes in rangefinder alt might never be fused)
m) EKF resets due to bad IMU data occur at most once per second
n) EKF3 accel bias fixed when an IMU is disabled
o) EKF3 variance constraint fix used to prevent “ill-conditioning”
p) GPIO pin fix on CubeOrange, F4BY, mRoControlZeroF7, R9Pilot
q) GPS blending fix that could have resulted in the wrong GPS being used for a short time
r) Guided mode yaw rate timeout fix (vehicle could keep yawing even if companion computer stopped sending target)
s) Log file list with over 500 logs fixed
t) MAVlink2 serial ports always send MAVLink2 messages (previously waited until other side sent MAVLink2)
u) Motor Test, Turtle mode respect emergency stop switch
v) Omnibusf4pro bi-directional dshot fix
w) PosHold braking fix if SCHED_LOOP_RATE set to non-default value
x) POWR log message MCU voltage fix (min and max voltage were swapped)
y) Precision landing in RTL activates even if pilot had earlier deactivated by repositioning in Land
z) Proximity sensor fix when using MAVLink lidars in non-forward orientations
aa) RC handover between IOMCU RC input and a secondary RC input on a serial port fixed
ab) Real-Time-Clock (RTC) oldest possible date updated to Jan-2022
ac) RPM sensor fix to avoid “failed to attach pin” spam to GCS
ad) SPRacingH7 firmware install fix
ae) STM32 DMA fatal exceptions disabled (caused watch dogs reboots with zero information)
af) Terrain reference adjustment ensures alt-above-terrain is zero at takeoff (see TERRAIN_OFS_MAX)
ag) Tricopter, Coax copter fin trim fix when using DShot/BLheli
Thanks very much to everyone who participated in the beta release and to the many developers who contributed to this release!
