I can’t arm the copter, because of “Prearm: safety switch” message
I have no safety switch installed and BRD_SAFETYENABLE disabled.
The motors keep beeping endless (so i guess they don’t get any signal). The only way to get out of this endless loop is to powercycle the pixhawk
The strange thing is: That happens only approx. one in ten times.
Firmware = Copter 3.6.0; ChibiOS
Could you arm the copter during your "endless esc beeping ? Probably not. You should see a message in Mission Planner that tells you, why arming isn’t possible. That means: You see the message only if you try to arm.
Maybe here’s a workaround:
Set BRD_SAFETYOPTION to 0 and BRD_SAFETY_MASK to 16383
I’m not sure whether that’s a working solution, but i haven’t seen any endless beeping loop since i made these changes.
It shouldn’t do this anymore if both BRD_SAFETYENABLE and BRD_SAFETYOPTION are set to zero. I found this issue some time back and @tridge fixed it.
The confusing part is that BRD_SAFETYENABLE does not truly disable the safety switch. BRD_SAFETYOPTION must also be set to zero to disable it. I’m not fond of that logic, but it’s the way it is right now.
I am not sure how BRD_SAFETYOPTION works. Mine was set to 3 (number 3 is not documented on the full parameters list in the arducopter docs), now is 0 and looks like it works.
The BRD_SAFETYENABLE only sets the boot-up state of the I/O. The SAFETYOPTION was put in to prevent hardware fault from shutting down the I/O in flight, and to set how you want the safety switch to work. But then I found it didn’t work anyway. tridge looked at it and he wrote a small patch that looks at the state of the I/O and the desired setting, and if a hardware fault causes it to try to shut down the I/O in flight, and if the SAFETYOPTION is set to zero, it will not shut it down.
I tested tridge’s patch and it works.
This does not address the somewhat confusing logic of these settings, as most people are going to think that if BRD_SAFETYENABLE is set to zero that it should be disabled totally. But at the present time that’s not how it works.
There is still a bug in that code that causes the intermittent self-enabling of the switch circuit. tridge’s patch prevents it from being a problem with the proper settings. It is not related to ChibiOS. It happens with NuttX too. But IMO tridge’s patch made it so it’s not a serious problem for 3.6, and the rest of that code and logic can be looked at later.
