HOW CAN I SETUP frame for y6b ??? value 10 write me UNKNOWN !
Why the caps lock? Please write properly, thereâs no need for that.
Have you set FRAME_CLASS to 5?
yep, and fliped on start, so seems like y6A
@ Rolf
had same issue on pixracer - slow parameter transfer.
Found: In 3.5 serial5_baud defaults to 921600 but should be 921. Changed it and wifi works fine again.
Hubertus
Flipping doesnât mean it is acting like Y6A. I just looked at code and it is the same as before merging all frames into one binary. Please open a new topic with your issue (with a log!).
That was almost certainly a coincidence, writing 921600 or 921 shouldnât make any difference.
I have FRAME CLASS and FRAME TYPE to choose
In a 250 cuad, I suppose to set 1 in the two params?
@Hubertus_Paetow
Thanks for the information. Tried 921 and another wifi-adapter with the same issue. Perhaps its a problem of Win10 & MissionPlanner. On my android with tower no problems.
Rolf
its dont mean , but can be it reason. becouse y6A have other order of motors same flip was happend in 3.3 when i set wrong select frame
You´re right. Problem occurs randomly and sometimes disappears when changing the baudrate in MP.
Wifi worked fine in 3.4.
Hubertus
FRAME_TYPE is the same as the old FRAME parameter. The FRAME_CLASS corresponds to the old different firmwares (hexa, octa, etc.). So for a quad you put FRAME_CLASS to 1, FRAME_TYPE should be the same as you had in the FRAME parameter (actually if you upgrade from a previous version this should already be set as only the name changed).
The wifi issues arenât an ArduPilot problem. If you read this long topic, youâll see that other people also have problems and an update to the Wifi board helped. As Iâve said there, from an ArduPilot perspective, the wifi connection to the board is just another serial port, we donât do anything different from a telemetry port.
Iâve flashe auav pixracer today with ac3.5rc1, one of the issues was that I wasnât able to save any of the parameters via esp8266 bridge, flashed back ac3.4.5 and able to save params again. (I couldnât save Arming Check 0).
Just reflashed ac3.5rc1 and ac3.4.5 and ac3.4.4 wifi bridge is almost useless on ac3.5rc1, takes forever to download params and will never save any, always return an error. flashed ac3.4.5 and all is back to normal.
@artemen,
Thanks for testing. Iâve reproduced the issue and added it as a to-do item to fix for AC3.5. https://github.com/ArduPilot/ardupilot/issues/5799
I have realized this also with Copter 3.5Rc1 and Rover 3.1.1. Pixracerâs both.
The same issue with Frsky telemetry⌠At least on pixracer. Didnât have time to check OSD, but I anticipate the same resultâŚ
Frsky Telemetry is working for me. PixRacer to an XSR and on the Taranis no problem as with previous version. Using telemetry option â4â (Frsky Sport) in Mission Planner.
I am using frsky D with D4RII.
Went back to ac3.4.5 all is back.
Double checked all frsky telemetry settings an hour ago.
Drotek Tiny RTK is already supported by Arducopter
