filiperosa
(Filiperosa)
December 20, 2017, 6:00pm
#1
Hi, I’m trying to set motor’s PWM publishing to /mavros/rc/override topic but I get no results and just get the message: "No handlers could be found for logger “rosout”.
I’m using Erle Brain 3 with the default ArduCopter firmware. Running amp.service, ros.service and mavros.service.
Trying to set PWMs using the command below:
$ rostopic pub /mavros/rc/override mavros_msgs/OverrideRCIn “channels: [1500, 1500, 1500, 1550, 1500, 1500, 1500, 1500]” -r 130
Does anyone know the proper way to do it?
Best,
Filipe
LanderU
(Lander U)
December 21, 2017, 8:46am
#2
Hi @filiperosa ,
ROS master is working well?
Paste here the output of:
sudo systemctl status -l ros.service
Regards,
@LanderU
filiperosa
(Filiperosa)
December 21, 2017, 2:54pm
#3
Hi @LanderU ,
this is the output I get:
ros.service - ROS Kinetic service
Loaded: loaded (/lib/systemd/system/ros.service; enabled)
Active: active (running) since Wed 2017-12-20 19:17:14 UTC; 1h 19min ago
Main PID: 573 (bash)
CGroup: /system.slice/ros.service
|-573 bash /opt/ros/kinetic/setup-ros.bash
|-846 /usr/bin/python /opt/ros/kinetic/bin/roscore
|-890 /usr/bin/python /opt/ros/kinetic/bin/rosmaster --core -p 11311 -w 3 __log:=/root/.ros/log/64b024d8-e5ba-11e7-b175-b827ebaae132/master.log
`-938 /opt/ros/kinetic/lib/rosout/rosout __name:=rosout __log:=/root/.ros/log/64b024d8-e5ba-11e7-b175-b827ebaae132/rosout-1.log
Dec 20 19:17:14 erle-brain-3 systemd[1]: Started ROS Kinetic service.
Hugo
(Hugo Sardinha)
November 7, 2018, 3:35pm
#4
Is there anything to add on this topic?
I am having the same issue…
I should say when I can do rostopic echo to any topic that is not mavros . When I do rostopic info to a mavros topic i get something like this
erle@erle-brain-3 ~ $ rostopic info /mavros/imu/data
Type: sensor_msgs/Imu
Publishers:
Subscribers: None
Thanks,
Hugo
