Ah that’s old school… If you have dshot go to the parameters page and select Dshot 150 save and power off and on make sure your props are off. then one more radio cal to be sure.
looking at HobbyWing Platinum 60A I don’t think they are dshot. Bummer.
Last time in plane i could not get the radio calibration/esc work with non dshot esc’s. if you have an extra Dshot esc you could try it. Or manually input the endpoints.
Another drone operator had recently issues arming because the throttle trim setting had been changed.(on the radio) - Perhaps check those quickly just to make sure it’s not something simple like that.
My ESC’s cheatsheet states that I have to calibrate it at first start, but I think I’ve done that before, and I even spun the motor before, but now, when ESC is no longer connected directly to a motor, but rather a Flight Controller, it stopped working. And seems like I can’t calibrate it while it’s connected to a FC and I really don’t want to reconnect the ESC straight to the motor.
Why are you worried about connecting to motors?
As long as you don’t have props on there is no problem.
The other thing you can do is using a 12V power supply, like an old style phone charger or router power plug, cordless tool charger,…as long as it is 12DC regulated. In that way there isn’t enough electrical current available to really power up a motor to full speed. (Unless its a small motor).
…but once again, without prop no problem.
I didn’t mean that connecting to a motor was a safety concern. I just said that when I connected ESC directly to a motor before – it worked. Now when my ESC is connected to a FC which is then connected to a motor – it doesn’t work.
@Googoogoogoose were you able to find a solution to this issue. I’m experiencing the same issue with a quadcopter build I have. It was working great for months and now this week when I arm the ESC beeps and when I disarm the ESC beeps once. The motors won’t spin up. The only way I can get it to arm is to disable RC Checks on prearm. Any idea.
