I’m trying to connect my Mac (V10.9.5 Mavericks) to APM Planner v2.0.18
I’ve downloaded the drivers per instructions. I also tried to decipher the ftdi pdf.
I do not understand the code on the terminal app. It does not seem to be responding as advertised.
I think the main problem is the “Serial Link” that I should be using is not listed. I’m pretty sure its a driver issue but I can’t figure out how to resolve it.
I’ve been searching online and youtube for info. Any help is very appreciated.
Last login: Thu Aug 20 13:18:02 on console
AGP-MB:~ HobiePilot$ cd /System/Library/Extensions/IOUSBFamily.kext/Contents/Plugins
AGP-MB:Plugins HobiePilot$ sudo mv AppleUSBFTDI.kext AppleUSBFTDI.disabled
WARNING: Improper use of the sudo command could lead to data loss
or the deletion of important system files. Please double-check your
typing when using sudo. Type “man sudo” for more information.
To proceed, enter your password, or type Ctrl-C to abort.
Password:
AGP-MB:Plugins HobiePilot$ sudo touch /System/Library/Extensions
AGP-MB:Plugins HobiePilot$ xxxxxxxx
-bash: xxxxxxxx: command not found
mv: rename AppleUSBFTDI.kext to AppleUSBFTDI.disabled/AppleUSBFTDI.kext: No such file or directory
This is how it came out. I initially put in my password where it said and nothing filled in at all. I still hit return and nothing happened so I input the 2nd line again. This time it did not ask for a password. Not sure if that worked but it did something, so I did that last line and that one does not look like it worked. I have not rebooted yet…
I’m confused (it easily done). If you are having an issue with the Pixhawk via USB. It should show up cu.usbmodem1 you can confirm this by typing in the Terminal application
THE FTDI driver problem is usually related to connecting via the telemetry radios. This require the baud to be set to 57600. the device is usbserial-XXXXX e.g.
bonney@slimvan:~$ ls /dev/cu.*
/dev/cu.Bluetooth-Incoming-Port /dev/cu.BumbleBee-WirelessiAP /dev/cu.RNBT-5F8E-RNI-SPP
/dev/cu.Bluetooth-Modem /dev/cu.HC-05-DevB /dev/cu.usbserial-DN0019M3
I have:
AGP-MB:~ HobiePilot$ ls /dev/cu.*
/dev/cu.BillsiPhone-WirelessiAP /dev/cu.Bluetooth-Modem
/dev/cu.Bluetooth-Incoming-Port /dev/cu.usbserial-00001014
I attached a screen shot. Seems that no telemetry coming in.
I did not know I could do that. It is now connected directly to the Iris now. It immediately powered up with the ok sound (forget tech term) but is normal sound.
I looked the APM Planner app and it would not even try to connect this way.
