Hello all, I am unable to connect my SITL to tower. I am trying through TCP. I have used the MavProxy command to add the ip address and port to the output of the sitl: output add ip address:port#.
But maybe I am using the wrong IP Address, I have used the phone IP Address and the port is 14550.
When I come to the tower application I also must add Server IP and Server Port. What should these parameters be? And how to connect through UDP?
I appreciate your help. Thank you.
