I would like to ask you some questions.
How should I connect the Jetson TX2 Developer Kit board with Pixhawk?
Is there an additional carrier board required to build the connection?
Thank you.
Thank you.
Have you seen this https://ardupilot.org/dev/docs/companion-computer-nvidia-tx2.html?
You need a cable between the Pixhawk and the TX2. Might b that you can do it with a carrier board too, but I don’t know which.
Thank you. I’ll try that.
