Connect Arduino to Pixhawk2/mission planner
Hi, I am a total freshman in using pixhawk and mission planner, but now I am in a project whose task is to send the sensor data from pixhawk (type is quadricopter) to arduino.
I tried to follow the tutorials from this link:
[Arduino (UNO) - MAVLink - PX4 no apparent connection + problem understanding the code from step by step guide]
(Arduino (UNO) - MAVLink - PX4 no apparent connection + problem understanding the code from step by step guide)
But the only thing I was getting is this kind of heartbeats(I am not sure if it is the correst word)
Can someone please help me with this?
Below is my current code
/* MAVLInk_DroneLights
by Juan Pedro López
// In case we need a second serial port for debugging
#define SOFT_SERIAL_DEBUGGING // Comment this line if no serial debugging is needed
#ifdef SOFT_SERIAL_DEBUGGING
// Library to use serial debugging with a second board
#include <SoftwareSerial.h>
#define RxPin0 0
#define TxPin0 1
int request = 0;
int receive = 0;
SoftwareSerial pxSerial = SoftwareSerial(RxPin0, TxPin0); // RX, TX || UNO - PX4
#endif
#include “mavlink.h”
//#include “common/mavlink_msg_request_data_stream.h”
// Mavlink variables
unsigned long previousMillisMAVLink = 0; // will store last time MAVLink was transmitted and listened
unsigned long next_interval_MAVLink = 1000; // next interval to count
const int num_hbs = 60; // # of heartbeats to wait before activating STREAMS from Pixhawk. 60 = one minute.
int num_hbs_pasados = num_hbs;
void setup() {
pinMode(RxPin0, INPUT);
pinMode(TxPin0, OUTPUT);
// MAVLink interface start
// Serial.begin(57600);
// [DEB] Soft serial port start
pxSerial.begin(57600);
Serial.println(“MAVLink starting.”);
#endif
void loop() {
// MAVLink
/* The default UART header for your MCU */
int sysid = 20; ///< ID 20 for this airplane. 1 PX, 255 ground station
int compid = 158; ///< The component sending the message
int type = MAV_TYPE_QUADROTOR; ///< This system is an airplane / fixed wing
// Define the system type, in this case an airplane -> on-board controller
// uint8_t system_type = MAV_TYPE_FIXED_WING;
uint8_t system_type = MAV_TYPE_GENERIC;
uint8_t autopilot_type = MAV_AUTOPILOT_INVALID;
uint8_t system_mode = MAV_MODE_PREFLIGHT; ///< Booting up
uint32_t custom_mode = 0; ///< Custom mode, can be defined by user/adopter
uint8_t system_state = MAV_STATE_STANDBY; ///< System ready for flight
// Initialize the required buffers
mavlink_message_t msg;
uint8_t buf[MAVLINK_MAX_PACKET_LEN];
// Pack the message
//mavlink_msg_heartbeat_pack(sysid,compid, &msg, type, autopilot_type, system_mode, custom_mode, system_state);
mavlink_msg_heartbeat_pack(20, 0, &msg, type, autopilot_type, system_mode, custom_mode, system_state);
// Copy the message to the send buffer
uint16_t len = mavlink_msg_to_send_buffer(buf, &msg);
// Send the message with the standard UART send function
// uart0_send might be named differently depending on
// the individual microcontroller / library in use.
unsigned long currentMillisMAVLink = millis();
if (currentMillisMAVLink - previousMillisMAVLink >= next_interval_MAVLink) {
previousMillisMAVLink = currentMillisMAVLink;
pxSerial.write(buf, len);
//Serial.println(“Ardu HB”);
#else
#endif
//Mav_Request_Data();
num_hbs_pasados++;
if (num_hbs_pasados >= num_hbs) {
  // Request streams from Pixhawk
Serial.println(“Streams requested!”);
#endif
Mav_Request_Data();
num_hbs_pasados = 0;
// Check reception buffer
comm_receive();
// Serial.print("receive: “);
// Serial.print(receive);
// Serial.print(” request: ");
// Serial.println(request);
void Mav_Request_Data()
request = request + 1;
// STREAMS that can be requested
Definitions are in common.h: enum MAV_DATA_STREAM
 MAV_DATA_STREAM_ALL=0, // Enable all data streams
 MAV_DATA_STREAM_RAW_SENSORS=1, /* Enable IMU_RAW, GPS_RAW, GPS_STATUS packets.
 MAV_DATA_STREAM_EXTENDED_STATUS=2, /* Enable GPS_STATUS, CONTROL_STATUS, AUX_STATUS
 MAV_DATA_STREAM_RC_CHANNELS=3, /* Enable RC_CHANNELS_SCALED, RC_CHANNELS_RAW, SERVO_OUTPUT_RAW
 MAV_DATA_STREAM_RAW_CONTROLLER=4, /* Enable ATTITUDE_CONTROLLER_OUTPUT, POSITION_CONTROLLER_OUTPUT, NAV_CONTROLLER_OUTPUT.
 MAV_DATA_STREAM_POSITION=6, /* Enable LOCAL_POSITION, GLOBAL_POSITION/GLOBAL_POSITION_INT messages.
 MAV_DATA_STREAM_EXTRA1=10, /* Dependent on the autopilot
 MAV_DATA_STREAM_EXTRA2=11, /* Dependent on the autopilot
 MAV_DATA_STREAM_EXTRA3=12, /* Dependent on the autopilot
 MAV_DATA_STREAM_ENUM_END=13,
 Data in PixHawk available in:
  - Battery, amperage and voltage (SYS_STATUS) in MAV_DATA_STREAM_EXTENDED_STATUS
  - Gyro info (IMU_SCALED) in MAV_DATA_STREAM_EXTRA1
// To be setup according to the needed information to be requested from the Pixhawk
const int maxStreams = 2;
const uint8_t MAVStreams[maxStreams] = {MAV_DATA_STREAM_EXTENDED_STATUS, MAV_DATA_STREAM_EXTRA1};
const uint16_t MAVRates[maxStreams] = {0x02, 0x05};
for (int i = 0; i < maxStreams; i++) {
mavlink_msg_request_data_stream_pack(system_id, component_id,
&msg,
target_system, target_component,
MAV_DATA_STREAM_POSITION, 10000000, 1);
   mavlink_msg_request_data_stream_pack(uint8_t system_id, uint8_t component_id,
      mavlink_message_t* msg,
      uint8_t target_system, uint8_t target_component, uint8_t req_stream_id,
      uint16_t req_message_rate, uint8_t start_stop)
mavlink_msg_request_data_stream_pack(2, 200, &msg, 1, 0, MAVStreams[i], MAVRates[i], 1);
#else
#endif
// Request: PARAM_REQUEST_LIST. Only for full log recording
Primitive: mavlink_msg_param_request_list_pack(uint8_t system_id, uint8_t component_id, mavlink_message_t* msg,
uint8_t target_system, uint8_t target_component)
// Configure
uint8_t system_id=2;
uint8_t component_id=200;
// mavlink_message_t* msg;
uint8_t target_system=1;
uint8_t target_component=0;
// Pack
mavlink_msg_param_request_list_pack(system_id, component_id, &msg,
  target_system, target_component);
// Send
  pxSerial.write(buf,len);
#else
#endif
void comm_receive() {
receive = receive + 1;
mavlink_status_t status;
// Echo for manual debugging
Serial.println("—Start—");
while (pxSerial.available() > 0) {
uint8_t c = pxSerial.read();
#else
while (Serial.available() > 0) {
uint8_t c = Serial.read();
#endif
// Try to get a new message
if (mavlink_parse_char(MAVLINK_COMM_0, c, &msg, &status)) {
  // Handle message
  switch (msg.msgid) {
    case MAVLINK_MSG_ID_HEARTBEAT:  // #0: Heartbeat
        // E.g. read GCS heartbeat and go into
        // comm lost mode if timer times out
Serial.println(“PX HB”);
#endif
break;
    case MAVLINK_MSG_ID_SYS_STATUS:  // #1: SYS_STATUS
        /* Message decoding: PRIMITIVE
              mavlink_msg_sys_status_decode(const mavlink_message_t* msg, mavlink_sys_status_t* sys_status)
        //mavlink_message_t* msg;
        mavlink_sys_status_t sys_status;
        mavlink_msg_sys_status_decode(&msg, &sys_status);
Serial.print(“PX SYS STATUS: “);
Serial.print(”[Bat (V): “);
Serial.print(sys_status.voltage_battery);
Serial.print(”], [Bat (A): “);
Serial.print(sys_status.current_battery);
Serial.print(”], [Comms loss (%): “);
Serial.print(sys_status.drop_rate_comm);
Serial.println(”]”);
#endif
break;
    case MAVLINK_MSG_ID_PARAM_VALUE:  // #22: PARAM_VALUE
              mavlink_msg_param_value_decode(const mavlink_message_t* msg, mavlink_param_value_t* param_value)
        mavlink_param_value_t param_value;
        mavlink_msg_param_value_decode(&msg, &param_value);
Serial.println(“PX PARAM_VALUE”);
Serial.println(param_value.param_value);
Serial.println(param_value.param_count);
Serial.println(param_value.param_index);
Serial.println(param_value.param_id);
Serial.println(param_value.param_type);
Serial.println("------ Fin -------");
#endif
break;
    case MAVLINK_MSG_ID_RAW_IMU:  // #27: RAW_IMU
              static inline void mavlink_msg_raw_imu_decode(const mavlink_message_t* msg, mavlink_raw_imu_t* raw_imu)
        mavlink_raw_imu_t raw_imu;
        mavlink_msg_raw_imu_decode(&msg, &raw_imu);
//Serial.println(“PX RAW IMU”);
//Serial.println(raw_imu.xacc);
#endif
break;
    case MAVLINK_MSG_ID_ATTITUDE:  // #30
              mavlink_msg_attitude_decode(const mavlink_message_t* msg, mavlink_attitude_t* attitude)
        mavlink_attitude_t attitude;
        mavlink_msg_attitude_decode(&msg, &attitude);
Serial.println(“PX ATTITUDE”);
Serial.println(attitude.roll);
// if(attitude.roll>1) leds_modo = 0;
// else if(attitude.roll<-1) leds_modo = 2;
// else leds_modo=1;
#endif
break;
    default:
Serial.print("— Otros: “);
Serial.print(”[ID: “);
Serial.print(msg.msgid);
Serial.print(”], [seq: “);
Serial.print(msg.seq);
Serial.println(”]");
#endif
break;
Go through this tutorial MAVLink and Arduino: step by step
Don’t forget: to get data from pixhawk you have to send your own heartbeat and request a stream (also in the tutorial)
The example above is for PX4, not ArduPilot, so if you’re testing against ArduPilot it’s not surprising it doesn’t work properly. Go through the tutorial above, it’s helped a lot of people.
