Arduino (UNO) - MAVLink - PX4 no apparent connection + problem understanding the code from step by step guide
Good evening community,
first of all i’m here to learn and understand as much i can on MAVLink.
I’m trying to connect and Arduino Uno with the PX4 to read different parameters (attitude, speed,…).
I used Software serial to entablish a connection between the UNO and the PX4 and a standard serial from the UNO to my pc to read variables value in the serial monitor.
CODE BELOW
The physical connections are as follow:
  1. PC - UNO : USB;
  2. UNO - PX4 : telem 2 (pin 9: Rx (yellow), pin 10: Tx (green)+ GND (black) on UNO);
  3. PX4 is powered via USB through an external power bank.
for the connection 2 i followed this picture:
http://ardupilot.org/copter/_images/3drRadioV1_pixhawk1.jpg
This is my connection:
Current PX4 setting for serial port are as in the picture below.
picture%202
I have a problem with the code posted here:
https://discuss.ardupilot.org/t/mavlink-and-arduino-step-by-step/25566
From his code i only commented or deleted the LEDs parts that were not useful for me.
I upload in the UNO the MAVLink library from the zip file in the link above (mavlink.zip).
“request” and “receive” variables are counters i added to verify how many times functions are executed.
The problem is that the UNO seems not to be able to reach the PX4, as once the “Streams requested!” message is displayed (line 93), no data is displayed, even if from the code it should (for example in lines 292-293 it should print the roll value, but as you can see from the picture below, nothing is printed).
I cannot undestand if the code has problems or if my connections are not correct.
If you need more information or any detail, just ask.
Before writing here i spent about 3 weeks undestanding the code as much as i could and trying to solve the problem.
As i have no more ideas on how to proceed, i though to ask here.
Thank you.
the code can be also seen from this site (feel free to modify it. it will be store):
https://www.codepile.net/pile/zMNdOB6n
CODE USED
/*  MAVLInk_DroneLights
    by Juan Pedro López
// In case we need a second serial port for debugging
#define SOFT_SERIAL_DEBUGGING   // Comment this line if no serial debugging is needed
#ifdef SOFT_SERIAL_DEBUGGING
// Library to use serial debugging with a second board
#include <SoftwareSerial.h>
#define RxPin0 9
#define TxPin0 10
int request = 0;
int receive = 0;
SoftwareSerial pxSerial = SoftwareSerial(RxPin0, TxPin0);  // RX, TX || UNO - PX4
#endif
#include "mavlink.h"
//#include "common/mavlink_msg_request_data_stream.h"
// Mavlink variables
unsigned long previousMillisMAVLink = 0;     // will store last time MAVLink was transmitted and listened
unsigned long next_interval_MAVLink = 1000;  // next interval to count
const int num_hbs = 60;                      // # of heartbeats to wait before activating STREAMS from Pixhawk. 60 = one minute.
int num_hbs_pasados = num_hbs;
void setup() {
  pinMode(RxPin0, INPUT);
  pinMode(TxPin0, OUTPUT);
  // MAVLink interface start
  // Serial.begin(57600);
  // [DEB] Soft serial port start
  pxSerial.begin(57600);
  Serial.println("MAVLink starting.");
#endif
void loop() {
  // MAVLink
  /* The default UART header for your MCU */
  int sysid = 1;                   ///< ID 20 for this airplane. 1 PX, 255 ground station
  int compid = 158;                ///< The component sending the message
  int type = MAV_TYPE_FIXED_WING;   ///< This system is an airplane / fixed wing
  // Define the system type, in this case an airplane -> on-board controller
  // uint8_t system_type = MAV_TYPE_FIXED_WING;
  uint8_t system_type = MAV_TYPE_GENERIC;
  uint8_t autopilot_type = MAV_AUTOPILOT_INVALID;
  uint8_t system_mode = MAV_MODE_PREFLIGHT; ///< Booting up
  uint32_t custom_mode = 0;                 ///< Custom mode, can be defined by user/adopter
  uint8_t system_state = MAV_STATE_STANDBY; ///< System ready for flight
  // Initialize the required buffers
  mavlink_message_t msg;
  uint8_t buf[MAVLINK_MAX_PACKET_LEN];
  // Pack the message
  //mavlink_msg_heartbeat_pack(sysid,compid, &msg, type, autopilot_type, system_mode, custom_mode, system_state);
  mavlink_msg_heartbeat_pack(1, 0, &msg, type, autopilot_type, system_mode, custom_mode, system_state);
  // Copy the message to the send buffer
  uint16_t len = mavlink_msg_to_send_buffer(buf, &msg);
  // Send the message with the standard UART send function
  // uart0_send might be named differently depending on
  // the individual microcontroller / library in use.
  unsigned long currentMillisMAVLink = millis();
  if (currentMillisMAVLink - previousMillisMAVLink >= next_interval_MAVLink) {
    previousMillisMAVLink = currentMillisMAVLink;
    pxSerial.write(buf, len);
    //Serial.println("Ardu HB");
#else
#endif
    //Mav_Request_Data();
    num_hbs_pasados++;
    if (num_hbs_pasados >= num_hbs) {
      // Request streams from Pixhawk
      Serial.println("Streams requested!");
#endif
      Mav_Request_Data();
      num_hbs_pasados = 0;
  // Check reception buffer
  comm_receive();
  //  Serial.print("receive:  ");
  //  Serial.print(receive);
  //  Serial.print("       request:  ");
  //  Serial.println(request);
void Mav_Request_Data()
  request = request + 1;
  // STREAMS that can be requested
     Definitions are in common.h: enum MAV_DATA_STREAM
     MAV_DATA_STREAM_ALL=0, // Enable all data streams
     MAV_DATA_STREAM_RAW_SENSORS=1, /* Enable IMU_RAW, GPS_RAW, GPS_STATUS packets.
     MAV_DATA_STREAM_EXTENDED_STATUS=2, /* Enable GPS_STATUS, CONTROL_STATUS, AUX_STATUS
     MAV_DATA_STREAM_RC_CHANNELS=3, /* Enable RC_CHANNELS_SCALED, RC_CHANNELS_RAW, SERVO_OUTPUT_RAW
     MAV_DATA_STREAM_RAW_CONTROLLER=4, /* Enable ATTITUDE_CONTROLLER_OUTPUT, POSITION_CONTROLLER_OUTPUT, NAV_CONTROLLER_OUTPUT.
     MAV_DATA_STREAM_POSITION=6, /* Enable LOCAL_POSITION, GLOBAL_POSITION/GLOBAL_POSITION_INT messages.
     MAV_DATA_STREAM_EXTRA1=10, /* Dependent on the autopilot
     MAV_DATA_STREAM_EXTRA2=11, /* Dependent on the autopilot
     MAV_DATA_STREAM_EXTRA3=12, /* Dependent on the autopilot
     MAV_DATA_STREAM_ENUM_END=13,
     Data in PixHawk available in:
      - Battery, amperage and voltage (SYS_STATUS) in MAV_DATA_STREAM_EXTENDED_STATUS
      - Gyro info (IMU_SCALED) in MAV_DATA_STREAM_EXTRA1
  // To be setup according to the needed information to be requested from the Pixhawk
  const int  maxStreams = 2;
  const uint8_t MAVStreams[maxStreams] = {MAV_DATA_STREAM_EXTENDED_STATUS, MAV_DATA_STREAM_EXTRA1};
  const uint16_t MAVRates[maxStreams] = {0x02, 0x05};
  for (int i = 0; i < maxStreams; i++) {
       mavlink_msg_request_data_stream_pack(system_id, component_id,
          &msg,
          target_system, target_component,
          MAV_DATA_STREAM_POSITION, 10000000, 1);
       mavlink_msg_request_data_stream_pack(uint8_t system_id, uint8_t component_id,
          mavlink_message_t* msg,
          uint8_t target_system, uint8_t target_component, uint8_t req_stream_id,
          uint16_t req_message_rate, uint8_t start_stop)
    mavlink_msg_request_data_stream_pack(2, 200, &msg, 1, 0, MAVStreams[i], MAVRates[i], 1);
#else
#endif
  // Request: PARAM_REQUEST_LIST. Only for full log recording
     Primitive: mavlink_msg_param_request_list_pack(uint8_t system_id, uint8_t component_id, mavlink_message_t* msg,
                   uint8_t target_system, uint8_t target_component)
    // Configure
    uint8_t system_id=2;
    uint8_t component_id=200;
    // mavlink_message_t* msg;
    uint8_t target_system=1;
    uint8_t target_component=0;
    // Pack
    mavlink_msg_param_request_list_pack(system_id, component_id, &msg,
      target_system, target_component);
    // Send
      pxSerial.write(buf,len);
    #else
    #endif
void comm_receive() {
  receive = receive + 1;
  mavlink_status_t status;
  // Echo for manual debugging
  // Serial.println("---Start---");
  while (pxSerial.available() > 0) {
    uint8_t c = pxSerial.read();
#else
  while (Serial.available() > 0) {
    uint8_t c = Serial.read();
#endif
    // Try to get a new message
    if (mavlink_parse_char(MAVLINK_COMM_0, c, &msg, &status)) {
      // Handle message
      switch (msg.msgid) {
        case MAVLINK_MSG_ID_HEARTBEAT:  // #0: Heartbeat
            // E.g. read GCS heartbeat and go into
            // comm lost mode if timer times out
            Serial.println("PX HB");
#endif
          break;
        case MAVLINK_MSG_ID_SYS_STATUS:  // #1: SYS_STATUS
            /* Message decoding: PRIMITIVE
                  mavlink_msg_sys_status_decode(const mavlink_message_t* msg, mavlink_sys_status_t* sys_status)
            //mavlink_message_t* msg;
            mavlink_sys_status_t sys_status;
            mavlink_msg_sys_status_decode(&msg, &sys_status);
            Serial.print("PX SYS STATUS: ");
            Serial.print("[Bat (V): ");
            Serial.print(sys_status.voltage_battery);
            Serial.print("], [Bat (A): ");
            Serial.print(sys_status.current_battery);
            Serial.print("], [Comms loss (%): ");
            Serial.print(sys_status.drop_rate_comm);
            Serial.println("]");
#endif
          break;
        case MAVLINK_MSG_ID_PARAM_VALUE:  // #22: PARAM_VALUE
                  mavlink_msg_param_value_decode(const mavlink_message_t* msg, mavlink_param_value_t* param_value)
            mavlink_param_value_t param_value;
            mavlink_msg_param_value_decode(&msg, &param_value);
            Serial.println("PX PARAM_VALUE");
            Serial.println(param_value.param_value);
            Serial.println(param_value.param_count);
            Serial.println(param_value.param_index);
            Serial.println(param_value.param_id);
            Serial.println(param_value.param_type);
            Serial.println("------ Fin -------");
#endif
          break;
        case MAVLINK_MSG_ID_RAW_IMU:  // #27: RAW_IMU
                  static inline void mavlink_msg_raw_imu_decode(const mavlink_message_t* msg, mavlink_raw_imu_t* raw_imu)
            mavlink_raw_imu_t raw_imu;
            mavlink_msg_raw_imu_decode(&msg, &raw_imu);
            //Serial.println("PX RAW IMU");
            //Serial.println(raw_imu.xacc);
#endif
          break;
        case MAVLINK_MSG_ID_ATTITUDE:  // #30
                  mavlink_msg_attitude_decode(const mavlink_message_t* msg, mavlink_attitude_t* attitude)
            mavlink_attitude_t attitude;
            mavlink_msg_attitude_decode(&msg, &attitude);
            Serial.println("PX ATTITUDE");
            Serial.println(attitude.roll);
            //            if(attitude.roll>1) leds_modo = 0;
            //            else if(attitude.roll<-1) leds_modo = 2;
            //            else leds_modo=1;
#endif
          break;
        default:
          Serial.print("--- Otros: ");
          Serial.print("[ID: ");
          Serial.print(msg.msgid);
          Serial.print("], [seq: ");
          Serial.print(msg.seq);
#endif
          break;
Send me a PM. I can try to help.
Regards,
Juan Pedro
thank you Juan, I’m sending it to you within today. :pray:
Gianluca
UPDATE in case anyone is having the same problem in the future.
PROBLEM SOLVED
The image i used to set the connections ( http://ardupilot.org/copter/_images/3drRadioV1_pixhawk1.jpg ) shows clearly a Pixhawk 4, but i have a Pixhawk 2 cube… i wrongly assumed that the telemetry scheme ports would have been the same for the 2 models, but that’s not true.
Instead, if you have a Pixhawk 2 cube, the scheme is basically inverted. So if you have a model like mine just use the schematic below insted of the one i reported above.
Juan Pedro’s code works perfectly (the one in his post and the one posted here) and after i changed the connections, i was able to see the stream from the serial monitor.
can you help me too?
My problem is that I want the system that I have made to stabilize the altitude. In addition, in this system with tasks, I need to communicate with the arduino pixhawk. If I give an example, let the system fix the altitude at 100 meters. how can i control motors with arduino via pixhawk. thanks
Thank you very much, my friend. I gave up because I could not provide any data transfer between arduino and pixhawk after 3 days of nonstop struggle. I saw your thread while One last time I searched the forum for this topic again. I saw that you wrote the example code from web “connecting arduino and pixhawk step by step” more cleanly and neatly. My code was similar to what you wrote, but because yours is neater, the code fits better in my head. I came to the conclusion that there was no error in the code and I started to think that there was a problem with the serial ports of the matek f405 card that I used for trial purposes. I opened all serial ports from Mission planner parameters and finally I was able to transfer information. The problem was that the serial port order on the matek f405 card was different from the serial order on the mission planner. As a result everything works and I can pass information between the two. Thanks again for sharing the sample code man.
hi, i’m a student in one of university in i have problem with build the program, i want to view the gps latitude longitude, altitude, in serial monitor on arduino, can you help me to make the program
(i’m sorry my english is bad)
