Hi guys,
I have Pixhawk 2.1 with Terraranger Tower, its working properly on avoidance function.
Now I need add sensors for upper and bottom avoidance.
Any idea?
Thanks for help.
Lada
Hi guys,
Any idea?
Thanks for help.
Lada
I don’t think currently you can have this setup out of the box with ArduPilot. They way I would try to go about it is have the two sensors looking up and down on i2c, unfortunately currently you can only specify a single PRX_TYPE parameter (meaning you can have either i2c or serial at a time).
When I was testing i2c sensors for obstacle avoidance back in November i run into some problems: Lidar doesn't work when RNGFND_ORIENT set to Up (24), assuming they were resolved there are two ways I would go around this:
In both cases you would quite likely need to modify the ArduCopter firmware.
Hope any of that helps!
Mat
Hi Mat
thanks for the answer, I expected this result.
I decided to choose to make a new type of PRX (Teraranger Tower + 2 TerabeeOne I2c) based on the expansion of “AP_Proximity_TeraRangerTower” by two TerabeeOne I2c sensors.
Modify other AP_Proximity related modules.
And I will test the new firmware on my octocopter (Pixhawk 2.1).
It’s good idea ?
Lada
Hi Lada,
Sorry, I didn’t get a notification about your reply. Your idea sounds good to me (of course be careful when flight testing it and try it one module at a time). Please let me know how it works out!
Cheers,
Mateusz
Does it works ? Any idea ? I am also looking for the same but n solution. Please help me. I will be using teraranger evo 60m as a tower ( 8 sensors ) for front, back, left and right obstacle avoidance but I want to setup the other two evo 60m. One evo 60m for terrain following, height maintaining withbottom obstacle avoidance and another one for top obstacle avoidance. So in total 10 sensors. 8 in tower 60m evo set and other two for bottom and top respectively ? Any help would be appreciated.
Does it works ? Any idea ? I am also looking for the same but n solution. Please help me. I will be using teraranger evo 60m as a tower ( 8 sensors ) for front, back, left and right obstacle avoidance but I want to setup the other two evo 60m. One evo 60m for terrain following, height maintaining withbottom obstacle avoidance and another one for top obstacle avoidance. So in total 10 sensors. 8 in tower 60m evo set and other two for bottom and top respectively ? Any help would be appreciated .
