16-01-2023 22:57:03 : T Failed
16-01-2023 22:57:03 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:57:03 : Config Error: fix problem then reboot
16-01-2023 22:56:58 : T Failed
16-01-2023 22:56:58 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:56:58 : Config Error: fix problem then reboot
16-01-2023 22:56:53 : T Failed
16-01-2023 22:56:53 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:56:53 : Config Error: fix problem then reboot
16-01-2023 22:56:48 : T Failed
16-01-2023 22:56:48 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:56:48 : Config Error: fix problem then reboot
16-01-2023 22:56:43 : T Failed
16-01-2023 22:56:43 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:56:43 : Config Error: fix problem then reboot
16-01-2023 22:56:38 : T Failed
16-01-2023 22:56:38 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:56:38 : Config Error: fix problem then reboot
16-01-2023 22:56:33 : T Failed
16-01-2023 22:56:33 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:56:33 : Config Error: fix problem then reboot
16-01-2023 22:56:28 : T Failed
16-01-2023 22:56:28 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:56:28 : Config Error: fix problem then reboot
16-01-2023 22:56:23 : T Failed
16-01-2023 22:56:23 : Config error: Board Validation $CHECK_BARO1_PRESEN
16-01-2023 22:56:23 : Config Error: fix problem then reboot
16-01-2023 22:56:23 : motors not allocated
16-01-2023 22:56:23 : RCOut: Initialising
16-01-2023 22:56:23 : CubeOrange 00490034 3239510C 38363839
16-01-2023 22:56:23 : ChibiOS: 45395b6a
16-01-2023 22:56:23 : ArduCopter V4.1.2 (03bf772a)
pixhawk cube orange problem
