HI peterbarker,
thank you for your reply.
Unfortunately I had no log, given that the problem didn’t allow to proceed with the configuration,unless it saved some data in a file that I don’t know where is placed.
Nevertheless , i tried to connect the board again, in order to find out something else to share for a better evalution of the problem, and I came to an apparent solution that I hope could find an explanation. I forgot to mention that I installed the oled (but NOT ENABLED in Mission Planner, although it was an oled that worked without problem on another F405 Wing board with INAV installed) and I was continuosly flashing and installing without taking care of it, it was always attached. The error persisted.
Incidentally I detached it from the board for making another attempt, just because it was bothering, and the board connected without problem.
Then I tried to connect again with the same oled installed and the error appeared again.
So a first conclusion was that the error was due to the oled.
I changed the oled with another that is installed on another Matek F405 wing ( with Arduplane installed) and that i know is working . With this oled there is no error, whether the oled is enabled or not
So my second ,trivial , conclusion is that the first oled is faulty.
I wonder if the oled alone can be the cause of unsuccesful configuration, mainly in the early phases when I can’t save anything that can help in debugging.
Sorry for this long reply, but I wanted to report all the actions i made in order to give you an alternative to the log for evaluating better the problem.
Now i will proceed with the configuration in order to see if everything is ok.
Corrado
